Topic: JScript Panel script discussion/help (Read 301094 times) previous topic - next topic
Re: JScript Panel script discussion/help
Reply #625
It is a conflict that occurs when you select in ESLyrics , Lyrics save scheme "Save when 60s or 1/3 of length have played".
I always thought the track title artist information has not changed, and will not affect it. :-[  I've changed the Lyrics save scheme. Thank you.
Reply #626
Can I compare two objects?
For example.
I have two massive of embedded covers
I need    if (embedded_1[0] == embedded_2[0] ) {.........}
or
var img1 = gdi.Image(img_path + "1.png"),
var img2 = gdi.Image(img_path + "2.png"),
if ( img1  ==  img2 ) {.........}
UR5EQF. Ukraine
Reply #627
Nope.
Reply #629
Is there a way to detect if the windows theme, or the screen settings were changed?
I'm late
Reply #630
Can you elaborate your question a bit? =)
Are you talking about Windows (e.g. Windows 10) theme? Or fb2k theme?
And there a lot of various screen settings as well both in fb2k and Windows...
Reply #631
I'm talking about the windows 10 theme. I have a script that reads the registry key value of the accent color and other related settings such as transparency mode and whether the accent color is applied to the window titlebar. The script than refreshes panel stack splitter in order to apply the new accent color, if changed. At the moment it is triggered by the on_size and by the on_playback_new_track events, but I would like to execute the script when one of those screen settings is changed, or when a new theme is applied.
I'm late
Reply #632
Well, there are no such functions in JScript. But you could probably make something with window.setInterval, i.e. get, compare and update theme values from registry every N seconds .
Reply #633
I'll give it a look, thanks.
I'm late
Reply #634
Does anybody have or know of a fairly simple script for an input box?
I'm late
Reply #635
I'm trying to replace the quicksearch toolbar with a jscript panel, but I'm not looking for a ready made script, which would probably have the same layout issues that the quicksearch toolbar has.  I've seen some configurations with a jscript searchbox, but they are far too complex to extrapolate the relevant code.
I thought I could build what I needed with the on_key_down and on_key_up events, but perhaps I've been a little too optimistic. What are the basic guidelines? Which callbacks should I use and, by the way, how do I get the proper character codes from key events?
I'm late
Reply #636
The issue is that JScript is not a web browser (which is my fucking dream... can you imagine how easy this stuff would be if we could use css/html for displaying panels and stuff -- I digress) so you can't really do an input box without completely faking EVERYTHING. i.e. you'd have to draw a rectangle on the screen. When the user clicks on it you have to draw a carat. When the user presses a key you have to draw a character to the screen and move the carat, you have to redraw on backspaces,.... etc.
I assume it *could* be done and maybe someone has done it, but it sounds awful to me.
There is some good news though. Doing something on keypresses is the easy part! The delete and ctrl-A keys call functions specific to my theme, but ctrl-F and Shift-F will run different foobar searches which might be good enough for you.
function on_key_down(vkey) {
var CtrlKeyPressed = utils.IsKeyPressed(VK_CONTROL);
var ShiftKeyPressed = utils.IsKeyPressed(VK_SHIFT);
switch (vkey) {
case VK_DELETE:
RemovePlaylistSelection(activeList, crop = false);
break;
case VK_KEY_A:
CtrlKeyPressed && selectAll();
break;
case VK_KEY_F:
CtrlKeyPressed && fb.RunMainMenuCommand("Edit/Search");
ShiftKeyPressed && !CtrlKeyPressed && fb.RunMainMenuCommand("Library/Search");
break;
Reply #637
switch (vkey) {
case VK_DELETE:
break;
case VK_KEY_A:
break;
case VK_KEY_F:
break;
Thanks a lot! This is the kind of starting point I'm looking for, and thanks for pointing me to the utils interface which for some reason I always fail to take into account. I still can't figure out a reasonable way to determine the character code, though. The combination of keycode and utils.IsKeyPressed is actually enough, but do I really have to go through all possible combinations one by one with a switch statement? Isn't there something like a keyboard mapping? Perhaps some array of values in the registry key?
Indeed! I'm still waiting for the sciter ui plug-in.
Yes, someone has. There is one in colagen's eole skin, even though I think the script is taken from the DUItunes skin by Falstaff. The code that implements the searchbox - at least where I'm able to recognize it - is within my reach, but it is hidden in longer multipurpose scripts, specific for that particular configuration or layout and with a maze of crossfererence to other js documents that make reading it a real pain in the neck, unless you are the author, I guess.
I'm late
Reply #638
[Thanks a lot! This is the kind of starting point I'm looking for, and thanks for pointing me to the utils interface which for some reason I always fail to take into account. I still can't figure out a reasonable way to determine the character code, though. The combination of keycode and utils.IsKeyPressed is actually enough, but do I really have to go through all possible combinations one by one with a switch statement? Isn't there something like a keyboard mapping? Perhaps some array of values in the registry key?
on_key_down returns standard ascii character codes. So values 65-90 correspond to A-Z (you need to check if VK_SHIFT is down for upper/lower though). If you want to output the key pressed to the screen you can do something like:
var str = String.fromCharCode(65);    // str now contains 'A'
Reply #639
Yes, the A-Z character codes, as well as the blank space and 0-9 characters, are the same as the key code, but all other symbols are messed up and I believe they change with the keyboard settings.
I'm late
Reply #640
I would assume punctuation and other printable characters are the same, but the other things probably require a select statement based off the VK_ defines.
Reply #641
We were on the wrong track! The on_char(code) callback is the one to look at: it takes the character code which is actually mapped to the key, rather than the key code.
I'm late
Reply #643
How do you escape the ampersand? The backslash doesn't seem to work as with other characters.
Basically: how can I write "Tom & Jerry" with a GdiDrawText method?
I'm late
Reply #644
Try "Tom && Jerry"
Reply #645
You need to add the flag  DT_NOPREFIX
https://github.com/marc2k3/foo_jscript_panel/blob/master/foo_jscript_panel/docs/Flags.txt#L16
https://github.com/marc2k3/foo_jscript_panel/blob/8ee7c4d084b535946922c05cadc3eba1b0e5c7e4/foo_jscript_panel/docs/Interfaces.txt#L1268
Reply #646
Thanks, both solutions work.
I'm late
Reply #647
Hello. I use
// @name "Text Reader"
// @author "marc2003"
1. I want to use it for viewing сue located of course in the playing folder, how to set the path? Default $directory_path(%path%) ... $directory_path(%path%)\*.CUE ... dont work
2. where to change the font type?
3. I want to display a text file with the name "discography.txt" in the root artist folder, the problem is that sometimes the depth of nesting, for example "artist \ album \" ... "artist \ album \ CD1"
Reply #648
EDIT
I'm late
Reply #649
The panel object uses the DUI or CUI font settings.
It depends on your folder naming standards. For example, if all your multiple discs were in folders named CD%discnumber% this could be your custom path:
$if($strcmp($directory(%path%),CD%discnumber%),$replace($directory_path(%path%),$directory(%path%),),$directory_path(%path%))
I'm late
