Topic: JScript Panel (Read 93151 times) previous topic - next topic
Re: JScript Panel
Reply #350
I've been checking the docs and there is some inconsistency where some methods return 4294967295 (or Math.pow(2, 32) -1) for things that aren't found and others are returning -1. I shall be making this consistent in the next update by using -1 for all because it's what people are used to when using Javascript.
edit: I've updated the Breaking Changes page on the wiki with the upcoming changes...
https://github.com/19379/foo-jscript-panel/wiki/Breaking-Changes#v131
Re: JScript Panel
Reply #351
v1.3.1 Beta1 (final release notes a few posts down)
Unfortunately, nothing new but fixes a few things and updates the docs to be more consistent. It's a beta because it has a few internal changes and I might not have caught everything.
https://github.com/19379/foo-jscript-panel/releases
My own "status bar.txt" sample in the "complete" folder was broken by this update so anyone else using it will need to re-import.
Re: JScript Panel
Reply #352
Out of curiosity, is there a reason why to remove the  IStyleTextRender interface?
Also, do you know if it possible, in a JS Smooth Playlist panel to reorder the tracks within playlist withdrag n' drop ? I can't do it. Too bad because it's possible with JSPlaylist (which is... not smooth sadly).
Maybe only Falstaff could tell...
Thanks anyway for your great component!
Decalicatan Decalicatan
Re: JScript Panel
Reply #353
The styletextrender thingy required an entire 3rd party project to be part of the Visual Studio solution and I selfishly got rid of it because I never use it. I know I should try and be more considerate of others but I'm mean!!  ;D WSH panel mod still works and there is WSH panel mod plus which shares many of the newer features with JScript Panel.
As for the playlist, you know the answer. They both use the same component!
Re: JScript Panel
Reply #354
Any chance of a non SSE2 build?
I thought maybe version 1.1.0 might work, but sadly, the author has removed all binaries on Github earlier than version 1.2.4.
Edit - I'm trying to run this on a XP machine. Saw in the changelog that 1.3.0 drops IE8/IE7/WINE support. So I tried 1.2.4 and got the same error. It's SSE2 related. Wish I knew how to compile it so I could try to do so with SSE2 requirement disabled.
Re: JScript Panel
Reply #355
This component has never ran on XP. Older versions with support for IE7/IE8 still required Vista or above.
The component it was based on (WSH panel mod) still runs on XP because it hasn't been updated since 2012...
https://code.google.com/archive/p/foo-wsh-panel-mod/downloads
Re: JScript Panel
Reply #356
OK, that makes sense, thanks! :)
Re: JScript Panel
Reply #357
v1.3.1
- FIX: Fixed a bug where plman.IsPlaylistItemSelected didn't return a proper boolean
       value. Thanks to TheQwertiest for reporting.
- FIX: Fixed a bug where plman.ShowAutoPlaylistUI didn't always return the correct
       boolean value.
- CHG: plman.MovePlaylistSelection now returns a boolean value to indicate success
       or failure.
- CHG: Update docs for consistency with actual component behaviour. Some methods
       which returned useless values have been updated to return nothing.
- CHG: On failure, these now return -1
       IFbFileInfo InfoFind
       IFbFileInfo MetaFind
       IFbMetadbHandleList BSearch
       IFbMetadbHandleList Find
       plman.ActivePlaylist
       plman.CreateAutoPlaylist
       plman.PlayingPlaylist
       This could potentially break some existing scripts. See
- CHG: Remove the whole IStyleTextRender interface. Anything that uses
       gdi.CreateStyleTextRender or was based on "glow text sample.txt"
       will no longer work
- CHG: Remove these IFbPlaylistRecyclerManager properties/methods:
       Id
       FindById
       RestoreById
No changes since beta.
Re: JScript Panel
Reply #358
With 1.3.1 and DarkOne4Mod, I now get the following error:
JScript Panel (DarkOne4Mod - Cover Panel v1.0 build20160929 by tedGo, includes partial code by T.P Wang)
Laufzeitfehler in JavaScript:
Das Objekt unterst├╝tzt die Eigenschaft oder Methode "CreateStyleTextRender" nicht
File: <main>
Line: 10, Col: 1
<source text only available at compile time>
Ist there a chance to correct this error?
Re: JScript Panel
Reply #359
File: <main>
Line: 10, Col: 1
See post above you:
       will no longer work
Re: JScript Panel
Reply #360
Thanks! So I have to wait for Tedgo to update his DarkOne4Mod. Is the previous version 1.3.0 of JScript Panel still available as a foobar2000 component?
Re: JScript Panel
Reply #362
Thank you marc2003! This works!  :)
Re: JScript Panel
Reply #364
I find that pretty hard to reproduce but I do get the occasional flicker.
FWIW, it looks like 3rd party PropertyList library is to blame but I have no idea how to fix it.
Re: JScript Panel
Reply #365
       will no longer work
Is there anything to replace " gdi.CreateStyleTextRender" thing?
Re: JScript Panel
Reply #366
I can consistently reproduce it though. The easiest way:
1. Open property list that is big enough to have scrollbar.
2. Click on top item to make it 'blue'.
3. Click on 'arrow down' button on scrollbar.
Result: value of first item is wrong now and matches the selected 'blue' item.
I've tried debugging a bit (lib is back from 2003, lol), but couldn't find the exact source of the problem. I've managed to prevent the bug from happening by removing "bHandled = FALSE" from OnLButtonUp method (PropertyList.h:605). But that's just brute-force programming -_-. This lib should be probably replaced some day with the more robust one (and may be a bit younger than 14 years old).
Re: JScript Panel
Reply #367
Doing that results in crazy buggy behaviour.  :o  :o
Re: JScript Panel
Reply #368
v1.3.2
- FIX: Improved handling of utf8 files without BOM. This affects files loaded
       via the PREPROCESSOR section and the Configuration window>Tools>Import button.
       They should now be treated the same as files with BOM.
Re: JScript Panel
Reply #369
I have the same question. My theme is using a bunch of TextRender stuff (GlowText, Shadow, RenderStringRect, etc.) and that's broken now. I had to roll back to 1.2.4 because I'm not sure what, if any, alternatives I've got.
Re: JScript Panel
Reply #370
Since I can't help myself breaking things, I've removed the component from the official repository. At least now people can't blindly update using the components updater.
If people want to update, they should check the changelog and download manually from github.
Re: JScript Panel
Reply #372
Recently, I've got this message.
JScript Panel (JS Smooth Browser v20151114-1630-340 by Br3tt aka Falstaff >> http://br3tt.deviantart.com)
JavaScript Runtime error:
Overflow
foo_jscript_panel\samples\js-smooth\js\jssb.js
Line: 1090, Col: 3
I've looked into that line.
this.cursorImage_normal = gdi.CreateImage(this.cursorw, this.cursorh);
Could anyone let me know how I can fix it?
Re: JScript Panel
Reply #373
Yay for fb.AlwaysOnTop!
Btw, do you know if it's possible to make on_main_menu_command_status_changed callback with fb2k api?
I can't give a definitive answer but I'm pretty sure it's not possible.
However, it looks like other components may use the config_object API and that would give other components (like JScript Panel) the option to read/write/get notified of their settings changes. Of course they'd have to make this public knowledge if it's already implemented.
Re: JScript Panel
Reply #374
ok, just forget it...
A rose will bloom, it then will fade.
