Topic: [foo_playcount] "Date Added" property not being written (Read 778 times) previous topic - next topic
I've been using Playback Statistics to sort my library by the date that I added each song, and it's been working fine for over a whole year. But now, I found out that at some point the %added% property stopped working.
This is when I sort by date added:
The Played column still updates so the component itself is working, but apparently some time after August 23rd the Added property stopped updating. (Obviously the N/As in the Played column are there because I haven't played the songs yet, but N/A has never shown up in the Added column.)
The whole Added property is missing from the properties panel on those songs (below), and even in the xml file after I exported one.
The Playback Statistics component is up to date (3.0.2) and I made sure to update foobar (1.3.8, was 1.3), but when I add new songs the Added column is still blank. (I even accidentally removed and reinstalled the component just now, so hey now I know that doesn't work either)
I'm also running Windows 10, but the upgrade was a while ago now.
I can't think of any major changes that I did to anything since that date that would affect it. But anyway, does anyone have any idea how to get it to start writing that property again?
Obligatory components list
Core (2015-03-26 07:45:52 UTC)
    foobar2000 core 1.3.8
foo_albumlist.dll (2015-03-26 07:42:40 UTC)
    Album List 4.5
foo_cdda.dll (2015-03-26 07:42:18 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2015-03-26 07:42:24 UTC)
    Converter 1.5
foo_dsp_eq.dll (2015-03-07 10:19:44 UTC)
    Equalizer 1.0
foo_dsp_std.dll (2015-03-26 07:42:26 UTC)
    Standard DSP Array 1.3.1
foo_fileops.dll (2015-03-07 10:19:10 UTC)
    File Operations 2.2.1
foo_freedb2.dll (2015-03-07 10:19:36 UTC)
    Online Tagger 0.7
foo_httpcontrol.dll (2013-04-26 16:12:30 UTC)
    HTTP Control 0.97.14-fb2kc
foo_input_std.dll (2015-03-26 07:45:52 UTC)
    Standard Input Array 1.0
foo_navigator.dll (2014-03-11 20:55:17 UTC)
    Navigator 0.8
foo_onewaysync.dll (2015-08-10 00:59:36 UTC)
    One Way Sync 0.2.9
foo_playcount.dll (2015-09-02 19:05:24 UTC)
    Playback Statistics 3.0.2
foo_playlist_bind.dll (2009-04-30 14:43:54 UTC)
    Playlist Bind 4.1
foo_plorg.dll (2011-05-05 23:03:00 UTC)
    Playlist Organizer 2.4
foo_rgscan.dll (2015-03-26 07:43:12 UTC)
    ReplayGain Scanner 2.2.1
foo_ui_std.dll (2015-03-26 07:45:52 UTC)
    Default User Interface 0.9.5
foo_uie_lyrics3.dll (2015-02-16 19:26:14 UTC)
    Lyric Show Panel 3 0.4.5
foo_unpack.dll (2015-03-26 07:42:42 UTC)
    ZIP/GZIP/RAR Reader 1.7.1
