Topic: wav cue file (Read 1470 times) previous topic - next topic
wav cue file
Can I use CueTool to split wav Cue File? If possible, what are the working steps and if there is tutorial would be much better. Many thanks!
wav cue file
You're asking about WAV (.wav) in the WavPack (.wv) forum?
CUETools can split a 16-bit, 44.1kHz .wav or lossless .wv image into individual tracks using the CUE file.
Leave advanced settings at default for now. (This may force ANSI filenames.)
For the GUI settings I suggest starting with:
  • Input: Folder browser
    • on the left, find & highlight the CUE (or the Image if it has an embedded CUE)
  • Output: Use template
  • Template: {select}
    • start with [%directoryname%\]new[%unique%]\%filename%.cue
    • This will create a new subfolder \new for the tracks
  • Action: Encode
    • leave the dropbox at default
  • Mode: Tracks
    • leave checkboxes alone for now
  • Audio Output: Lossless
    • Select WAV (wav) or WavPack (wv) from the top dropbox
click GO
One or more popup windows may appear. Make a choice or just click OK.
korth
