Multiple streams with foobar 2015-06-20 13:35:15 Hey guys, i was wondering.Is there any way of having more than one stream with foobar, to icecast.Because i am wanting to stream multiple genre's to my icecast server.thanks in advance
Multiple streams with foobar Reply #1 – 2015-06-20 16:18:12 First this topic shouldn't be in this category unless your are streaming multichannel audio, which I doubt..Foobar only outputs one file at a time , so you can't stream/play different files in the same instance.You would need two installations to stream different content.You can though stream the same content to different mountpoints in your icecast server, to provide different qualities using the streaming client.foo_streamer.http://www.geocities.jp/pirosoft12/
