Topic: lossyWAV 1.4.2 Development (was 1.5.0) (Read 41562 times) previous topic - next topic
Re: lossyWAV 1.4.2 Development (was 1.5.0)
Reply #100
Internally, block size is determined by sample-rate, e.g. 512 samples for 44.1/48 kHz; 1024 samples for 88.2/96kHz; etc..
FLAC blocksize can be varied independently of lossyWAV processing block-size.
Recently I have been using foobar2000 to convert 44.1/16 FLAC to lossyFLAC - setting foobar2000 to output 24-bit as input to lossyWAV (and scaling by 0.5 to give the ANS "room" to work).
--static and --dynamic set the minimum-bits-to-keep for each sample from a fixed datum (--static) or a dynamic datum based on block noise (--dynamic).
lossyWAV -q X -a 4 -s h -A --feedback 2 --limit 15848| FLAC -5 -e -p -b 512 -P=4096 -S-
Reply #101
Yes I've read about this; I was asking if it's possible to alter this to let LossyWAV use, for example, block size of 4096 samples for 44.1 kHz.
