Topic: Can anyone hear any voices in this? (Read 4119 times) previous topic - next topic
Hi, I was hoping someone could have a listen and see if they could hear anything or it was just me.
Get some professional help NOW!!  Because it's in your head and only your head.
No, there are no voices in these examples.
I am not the kind of person who would usually rush at the internet discussion board's "you are insane, seek help" button, but maybe you should write down what you think you hear from this and consult a professional for an opinion.
At some instances in the Test3 file there could be some sounds which, with a bit of imagination, vaguely resemble the moaning of zombies in a classic horror movie. But even that "with a bit of imagination, vaguely resemble" is a bit of a stretch.
Hi, I really appreciate your help by listening to the files I uploaded.  Can I post just one more please before I go to the doctor because I know there are voices in this I just want to know if they are saying anything threatening or such like.
I won't post any more files.
Thanks again.
Nothing intelligible or threatening that I can make out. I recommend you go see a general practitioner who can refer you to the correct specialist.
If anything, that sounds like a faint AM broadcast being picked up, but it's extremely vague.
This thread should only be used for samples.  Since the OP said he would not post any more, I will be closing it now.
The dedicated topic under which the above discussion should have occurred can be found here:
http://www.hydrogenaud.io/forums/index.php?showtopic=109103
