Topic: One particular CD produces EAC "File creation error" (Read 3642 times) previous topic - next topic
Hi
So I've rebooted, haven't changed a thing, yet I have one particular CD, actual both discs of a two disc set, that I can't rip. Whenever I put either of the two in EAC, I get file creation errors. EAC does create the cue sheet and the log file but cannot create the tracks.
Exact Audio Copy V1.0 beta 4 from 7. December 2014
EAC extraction logfile from 13. April 2015, 15:33
Cowpuncher / Brown Album
Used drive  : HL-DT-STDVDRAM_GSA-H10N   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : Yes
Read offset correction                      : 667
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:30.14 |         0    |    15763
        2  |  3:30.14 |  4:53.29 |     15764    |    37767
        3  |  8:23.43 |  3:07.32 |     37768    |    51824
        4  | 11:31.00 |  4:12.52 |     51825    |    70776
        5  | 15:43.52 |  3:59.27 |     70777    |    88728
        6  | 19:43.04 |  3:26.37 |     88729    |   104215
        7  | 23:09.41 |  2:55.47 |    104216    |   117387
        8  | 26:05.13 |  4:14.43 |    117388    |   136480
Track  3
     Filename C:\Users\Public\Music\Cowpuncher\1 - 03 -      - 15.wav
     Pre-gap length  0:00:01.64
     Copy aborted
No tracks could be verified as accurate
No errors occurred
End of status report
==== Log checksum ED3CD4CB1249756463C5055298464FE06151AF1F4E36B0CDCD2747FD9AED8839 ====
EAC extraction logfile from 18. April 2015, 19:22
Read mode : Burst
Quality                         : High
Add ID3 tag                     : No
Track  1
     Filename C:\Users\Public\Music\Cowpuncher\1 - 01 -      - Melt Canada.wav
     Pre-gap length  0:00:02.00
     Copy aborted
Track  2
     Filename C:\Users\Public\Music\Cowpuncher\1 - 02 -      - Renters.wav
     Pre-gap length  0:00:01.07
     Copy aborted
Track  3
     Copy aborted
Track  4
     Filename C:\Users\Public\Music\Cowpuncher\1 - 04 -      - Kill All The Artsts.wav
     Pre-gap length  0:00:01.08
     Copy aborted
Track  5
     Filename C:\Users\Public\Music\Cowpuncher\1 - 05 -      - Thank God For Pretty Girls.wav
     Pre-gap length  0:00:02.70
     Copy aborted
Track  6
     Filename C:\Users\Public\Music\Cowpuncher\1 - 06 -      - I Met Your God (In The Alley).wav
     Pre-gap length  0:00:00.25
     Copy aborted
Track  7
     Filename C:\Users\Public\Music\Cowpuncher\1 - 07 -      - Smashed Teeth.wav
     Pre-gap length  0:00:01.06
     Copy aborted
Track  8
     Filename C:\Users\Public\Music\Cowpuncher\1 - 08 -      - All We Are.wav
     Pre-gap length  0:00:01.35
     Copy aborted
No errors occurred
==== Log checksum 62EBDD147BBA5DDFA57C364E7EEB7AC606B9991C5601C9DB56E2D6465CB6FA29 ====
There's probably a character in the filename that EAC doesn't like (even if it looks fine to you).
I'd start with the content of the placeholder in your 'Naming scheme' producing the blank area in the log.
Filename C:\Users\Public\Music\Cowpuncher\1 - 03 - ____ - 15.wav
Or you can temporarily change the 'Naming scheme' (F9 > Filename > Naming scheme) to something really simple like just the %tracknr% placeholder and see if files are created.
korth
