Topic: Audibility of phase shifts and time delays (Read 23988 times) previous topic - next topic
In the MQA hype I've found the following claim:
MQA Hype
"However from more recent research it turns out that although humans can not hear frequencies above 20kHz, they are sensitive to timing of sounds to about 10 microseconds. So first you notice the arrival of a sound (quick change in air pressure, a very high frequency) and later on you actual hear what sound it is. To preserve this timing info in the audio signal 96kHz is therefor not enough, we actually need 192kHz."
Both the claim that "(humans) are sensitive to timing of sounds to about 10 microseconds" and
"To preserve this timing info in the audio signal 96kHz is therefor not enough, we actually need 192kHz"
seem to be completely wrong, based on what I know about human hearing and digital audio.
What are they talking about?
"So first you notice the arrival of a sound (quick change in air pressure, a very high frequency) and later on you actual hear what sound it is."
This must be their way of describing the terrific PRE-ringing!
x-axis is in us (microseconds). Notice how the dots are spaced at 44.1 kHz or roughly 23 us apart.
y-axis is linear in 0.1 divisions, with the max shown being ~0.6 or about -4.4 dBFS.
We take some impulsive signal, quantize it and visualize it as red dots. The corresponding blue line shows the upsampled version of the signal before quantization (the 'ideal' or target).
We then delay this signal by 10us, quantize it and visualize it as green dots. The blue line is again the upsampled, this time delayed signal before quantization.
The dots match our target... Even if we attenuate this signal by 60 dB first, we will see the effects of quantization and dither, yes, but the 10us delay does not disappear.
"I hear it when I see it."
In short, 10 microseconds is nowhere near the actual abilities of 4416 to convey timing differences among
signals is:  1/(44100*65536) =
3.460042871315193e-10  seconds. Less than a nanosecond.
The information that I am aware of related to the audibility of time differences is summarized here:
David L. Clarks AES paper about the audibility of time
Despite the possibility of "digital effects," the modest quality of the speakers, and the fact that the listeners were in effect being tested, every one of approximately 12 participants was able to match the time delays to within +/- 40 microseconds (about 1/2 inch). This finding confirms the clams of those who espouse the virtues of arrival time compensated loudspeakers.
Cool, words about audio from someone who doesn't understand sampling.
MQA Hype
The link is now broken.
Well using that formula we'd tread into the >1us 'resolution' range 70 dB down*. 90 dB down would be 10us.
*) This does not translate directly into what you see in a spectrogram. A 1ms long tone burst that reaches full scale would show up below -50 to -60 dB with a 65k FFT size in Audition.
Arny, they are not talking about phase in an absolute sense, but the phase relationship of the content within a track.
MQA Hype
Working again...
I didn't mean allpass filters either. That would be a constant phase shift at a given frequency.
I guess what they're talking about is some sort of quantization distortion along the x-axis. I doesn't make sense, but it doesn't need to for FUD.
Well, 1/ ( 2 pi bandwidth number_of_levels)
This hardly disproves your point, naturally!
J. D. (jj) Johnston
Thanks for the correction, JJ. Your correction seems to make the resolution even  more than my calculation said or 1.0990333934666109990166543854704e-10  seconds - about 0.1  nanoeconds.  No perceiving that with the ears, or its effects on frequency response.
So in order for that to degrade to 1us we're down ~80 dB.
The way I see it, the perceptual limit is about 40 uSec or 40 x 10E-6 seconds, and the resolution limit is about 1.1 x 10E-10.  so, the resolution limit is 40 x 10-4 below the perceptual limit which is 92 dB down.
When we are talking about timing, there are a lot of ways to quantify it.
For example Clark is talking about trying to synchronize two identical sounds that are operating concurrently. Cancellations which lead to steady-state frequency response differences are a big part of this.
When we are talking about hearing the difference between two different musical sounds, then there are no steady state frequency response differences to listen for, and this is more like me ABXing two files that are not mixed but are displaced in time about a week ago. Its like hearing an echo which puts the perceptual limit up into the range of milliseconds, not microseconds.
Thus we find two false claims that are being used to sell MQA.
One is that the ears are at from 4 to over a thousand times more sensitive than they are to timing differences, and that 4416 is at least 10.000 times worse than it is at transporting timing information.
"However from more recent research it turns out that although humans can not hear frequencies above 20kHz, they are sensitive to timing of sounds to about 10 microseconds."
"recent"?!
Klumpp, R. G.; and Eady, H. R. (1956).
Some Measurements of Interaural Time difference Thresholds.
Journal of the Acoustical Society of America, vol. 28, no. 5, Sept., pp. 859-860.
It's the earliest reference I know to 11 us.
Some of it is reproduced on pages 4+5 of this...
http://web.mit.edu/hst.723/www/ThemePapers.../Grantham95.pdf
Are we entering Kunchur-land again here?
That's not what I meant. 2^16 values are only available to a tone that reaches full-scale. 80 dB (roughly 13 bits) down we're left with 2^16 * 10^(-80/20) values.
"recent"?!
Thanks. Clark's experiment was based on loudspeaker listening, while it appears that Grantham95 is based on headphones. That one would be 4 times the other seems to make sense.
The big mistake in the MQA hype is then that somehow 44/16 can't hack reproducing time delays on the order of a few microseconds. It can hack it, and its resolution goes many orders of magnitude below that.
Read here: Kunchur 2007 Temporal Resolution Paper
His Faux pas about serious problems with the temporal resolution possible with 4416 seem to have been avoided, but then he goes down the Stuart road.
However in the same year, same journal he published this:
Other Kunchur time resolution paper
Every component’s bandwidth limit
(even if it behaves perfectly linearly) causes it to have a
finite relaxation time of ??1/?max; use of digital carriers
limits the shortest resolvable time interval to about half
the sampling interval (which for CD would be 11 ?s);
Even if his was audible- I have serious doubts that loudspeakers of the same make an model would be  able to reproduce this timing accurately anyway - people would have to calibrate their speahkers within microseconds so they matched - marketing madness
Are you suggesting that all future resolution specifications be based on FS = -80 dB?
At that rate 4416 only has 16 dB dynamic range.
No, but it is good that you bring up SNR because this 'resolution' is proportional to SNR. That's all. I was just curious where this formula would spit out 1us/5us.
