AMR converter
Reply #1 –
You can try Nokia Multimedia Converter. There is no link to this app as Nokia servers were shut by Microsoft, but you can find it elsewhere. I would guess that any AMR encoder would be at least 10 years old since last update, and last NMC version AFAIK is 2.0 from 2003.
About NMC - setup file is just an archive. It's not fully compatible with modern Windows, so best way to use it would be to open the setup.exe archive, and copy MMConverter_Pro folder and then register MultimediaConverter.dll with regsvr32. This way you'll get GUI exe and CLI exe:
C:\Programs\nmm>MMConverterCon.exe
Multimedia Converter 2.0 console version
Copyright (c) 2000-2003 Nokia Corporation
USAGE: MMConverterCon [options]
-i infile Input file name (required)
-o outfile Output file name without file extension
Appropriate file extension will be added
by the application.
-st startTime Conversion start time in seconds [0 sec]
-sl sizeLimit Size limit for the converted file in kB [0 kB]
Set to 0 to disable size limit.
-p Turn off user interaction [on]
-h This message
Video options:
-v imageSize Video image size [qcif]
qcif => 176x144
subqcif => 128x96
-fr frameRate Target frame rate in frames per second [15 fps]
-intra period Key frame period in seconds [15 sec]
Set to 0 to disable INTRA frame update
-br videoBitRate Video bit rate in kbps [64 kbps].
Must be between 20kbps and 64kbps.
128kbps is an exception:
You can use 128kbps bit rate, but it will only
work with certain phones.
Audio options:
-a audioType Audio type[amr]
amr => AMR
wbamr => Wide Band AMR
-amr AMRMode Audio bit rate [7]
AMR WBAMR
0 => 4.75 kbps 6.60 kbps
1 => 5.15 kbps 8.85 kbps
2 => 5.90 kbps 12.65 kbps
3 => 6.70 kbps 14.25 kbps
4 => 7.40 kbps 15.85 kbps
5 => 7.95 kbps 18.25 kbps
6 => 10.2 kbps 19.85 kbps
7 => 12.2 kbps 23.05 kbps
8 => 23.85 kbps
