Topic: help needed (Read 3945 times) previous topic - next topic
help needed
hey, i cant for the life of me get my lil test to compile any help?
main.h
#include "../SDK/initquit.h"
#include "../SDK/titleformat.h"
#include "../SDK/modeless_dialog.h"
#include "../SDK/play_control.h"
#include "../SDK/componentversion.h"
#include "../helpers/unicode_helper.h"
class initquit_albumlist : public initquit
public:
    virtual void on_init();
    virtual void on_quit();
static service_factory_single_t<initquit,initquit_albumlist> foo;
DECLARE_COMPONENT_VERSION("TEST","0.0",0)
main.cpp
#include "main.h"
void initquit_albumlist::on_init() {
void initquit_albumlist::on_quit() {
and i got the 2 the foobar_sdk.dsp and pfc.dsp set as dependancys....
well thats everything techncal about it i think... anyone know why i get
ain.obj : error LNK2001: unresolved external symbol "public: virtual void __thiscall service_base::service_release(void)" (?service_release@service_base@@UAEXXZ)
main.obj : error LNK2001: unresolved external symbol "private: static class service_factory_base * service_factory_base::list" (?list@service_factory_base@@0PAV1@A)
main.obj : error LNK2001: unresolved external symbol "public: static struct _GUID __cdecl initquit::get_class_guid(void)" (?get_class_guid@initquit@@SA?AU_GUID@@XZ)
main.obj : error LNK2001: unresolved external symbol "char const * __cdecl core_api::get_my_file_name(void)" (?get_my_file_name@core_api@@YAPBDXZ)
any help?
thanks in advance
Bizzy
help needed
Did you add component_client.cpp to your main project?
help needed
gives even more errors :S
main.obj : error LNK2001: unresolved external symbol "public: virtual void __thiscall service_base::service_release(void)" (?service_release@service_base@@UAEXXZ)
component_client.obj : error LNK2001: unresolved external symbol "class foobar2000_client g_client" (?g_client@@3Vfoobar2000_client@@A)
component_client.obj : error LNK2001: unresolved external symbol "bool __cdecl is_path_separator(int)" (?is_path_separator@@YA_NH@Z)
component_client.obj : error LNK2001: unresolved external symbol "public: __thiscall string_utf8_from_wide::string_utf8_from_wide(unsigned short const *)" (??0string_utf8_from_wide@@QAE@PBG@Z)
component_client.obj : error LNK2001: unresolved external symbol "public: __thiscall string_wide_from_ansi::string_wide_from_ansi(char const *)" (??0string_wide_from_ansi@@QAE@PBD@Z)
component_client.obj : error LNK2001: unresolved external symbol "class foobar2000_api * g_api" (?g_api@@3PAVfoobar2000_api@@A)
component_client.obj : error LNK2001: unresolved external symbol "public: static void __cdecl cfg_var::config_on_app_init(void)" (?config_on_app_init@cfg_var@@SAXXZ)
component_client.obj : error LNK2001: unresolved external symbol "public: void * __thiscall mem_block::copy(void const *,int,int)" (?copy@mem_block@@QAEPAXPBXHH@Z)
component_client.obj : error LNK2001: unresolved external symbol "public: void * __thiscall mem_block::set_size(int)" (?set_size@mem_block@@QAEPAXH@Z)
help needed
I don't know what compiler you used but I created MSVC project file for you that compiles with said compiler without hickups, download.
help needed
UPX
'upx' is not recognized as an internal or external command,
operable program or batch file.
Error executing c:\windows\system32\cmd.exe.
any idea ???
(MSVC++ using ur test)
help needed
nm. removed post build stuff.. its ok now  thanks
help needed
btw, is there a notification like the initquit, for when foobar is fully loaded?
cos my code includes Sleep(150) inside in infanate loop, and foobar doesnt load cos of it :s
any help?
