Topic: SoX downconversion (Read 3623 times) previous topic - next topic
SoX downconversion
I'm including all this just in case anyone is interested in trying the comparisons--definitely not asking anyone to waste time going over all this.
No claims of validity or reliability are being made here--all of that could ONLY occur under controlled laboratory conditions. The following is just doing what's possible in forum format online.
The original source file for conversion (saving space here) is available online at http://www.naimlabel.com/musicstore-test-files.aspx z
The original file would be the very last line on this page, the Classical in WAV, 192/24
I used it renamed as Beeth_192.wav
SoX was downloaded from Sourceforge, command line used was adapted from an example here: http://smyck.net/2014/01/18/resampling-con...ng-audio-files/
sox Beeth_192.wav -b 16 Beeth_44.wav rate -v -s 44100  (with my own filenames, of course)
Further SoX recipes welcome.
SoundForge reports these Statistics for the 192/24:
                                                 Left Channel           Right Channel
Cursor position (Time)           00:00:00.000           00:00:00.000
Sample value at cursor (dB)     -Inf.                         -Inf.
Minimum sample position (Time)   00:00:04.832           00:00:03.639
Minimum sample value (dB)       -0.091                         -0.361
Maximum sample position (Time)   00:00:05.207           00:00:04.019
Maximum sample value (dB)       -0.644                         -1.380
RMS level (dB)                           -16.607               -17.188
Average value (dB)               -101.089               -99.885
Zero crossings (Hz)                     763.96                 692.57
SoundForge reports these Statistics for the 44.1/16:
Minimum sample value (dB)       -0.116                         -0.369
Maximum sample value (dB)       -0.653                         -1.417
RMS level (dB)                           -16.607               -17.187
Average value (dB)               -Inf.                         -Inf.
Zero crossings (Hz)                     756.16                 685.10
[attachment=8236:Beeth_44.wav]Comparison between the original and the SoX conversion yielded non-significant results at alpha = .05
Results posted in this thread: http://www.hydrogenaud.io/forums/index.php?showtopic=108758
Specific result for testing this down-conversion is at:
