Mute/Unmute button 2015-03-15 16:35:52 Hello guys! Your program is absolutely fantastic, but there is no "Mute" option in the default UI. Could you please add it?Mutting is necessary when fb2k is playing stream.
Mute/Unmute button Reply #1 – 2015-03-15 16:44:47 right click existing buttons>customise. Last Edit: 2015-03-15 16:45:15 by marc2003
Mute/Unmute button Reply #2 – 2015-03-15 18:30:45 You can also use 'File/Preferences/Keyboard shortcuts' if you don't want to bring up the player window every time.If you check the [ ] global hotkey box the shortcut will work regardless if foobar has focus. Last Edit: 2015-03-15 18:33:44 by Daeron
