Topic: foo_chronflow – Coverflow (Read 34390 times) previous topic - next topic
Re: foo_chronflow – Coverflow
Reply #125
Hey, i have this message when i want to install the componenet: Could not load component "foo_chronflow-master.zip": Unsupported format or corrupted file.
Reply #127
Is there any way this can display artwork from a folder based the track rather than an album? Quite a lot of tracks are singles, and (depending on the grouping setting) it tries to add them all to the first single, to make an album that doesn't exist. I tried replacing the 'No Cover Image' with a URL to the artwork folder, ending in \%artist% - %title%, but it didn't like it! Or, can a different code be entered into the Database filter box? Also, what is the grouping syntax for %album% when there is one, otherwise %track%?? Thanks for a lovely piece of FB2K input!
Reply #128
Sorry, I didn't quite get what you are asking for. Do you want one "album" per single? Then you need to change your grouping settings accordingly.
Reply #129
Thanks for the response. That's part of it, but it's more the 'album art'. When the track is a single, I'd prefer that the artwork was for that track only, preferably sourced from the FB2K Artwork standard: <A:\SongImages\$stripprefix(%filename%.jpg>. At the moment, it groups all singles by the artist from one year into an 'album' and shows them under the first track's artwork. The grouping regime is <[$stripprefix(%artist%,the)][%date%][%album%]>, display syntax is <%artist%$crlf()[%album%]>. This all works great for albums, but not singles...
Reply #130
You need to replace [%album%] with $if2(%album%,%title%)
