Topic: Codec. With least cpu overhead (Read 1682 times) previous topic - next topic
Rather than maintain copy of my music in lossless and lossy formats, I have decided to just put FLAC files on my Ampache server and allow it to transcode the files to vbr 0 MP3s.
The only downside I see to this is that the server will be doing a lot of encoding as I sit at my desk and listen top my music on my phone.
Which led me to wonder, which lossy codec would give meet least gpu impact?
What codecs can you use? Which encoders could you use on your server?
"I hear it when I see it."
Assuming you mean CPU, it depends on how much bitrate you're willing to use.  CPU load can be made extremely low by using a low quality encoder at very high bitrate.
Then again, if this is a PC system, the CPU load is probably negligible anyway.
I would use Helix MP3 encoder for on-the-fly encoding if your goal is low CPU usage. Helix is very fast and the quality is on par with LAME at higher bitrates.
It's better to use CBR for streaming, otherwise time display will either not work or show invalid value. My choice would be 256kbps CBR with Helix. Probably you can go lower.
If your aim is gapless playback, sadly Helix doesn't support encoding files like that. I wonder why the community haven't integrated that feature into the source code. Maybe it's more difficult than simply writing some offset values.
Another fast encoding option is Vorbis with Lancer mod. You can go for lower bitrates using Vorbis. There are aoTuV + Lancer builds available which are both tuned for quality and speed.
So you want to do this for streaming over a network where bandwidth is scarce ...? Or ...?
Is it only for you? Encoding at realtime for one user shouldn't be too taxing?
GPU or CPU? I have no idea whether architecture makes a lot of difference if you want to let a GPU do the job.
Maybe not what you need, but worth mentioning if you run Ampache on a Linux box: have you had a look at http://khenriks.github.io/mp3fs/ ? It encodes to mp3 if and when you read the FLAC.
