Topic: Change Request: Performance "Trick" on very large Libraries (Read 965 times) previous topic - next topic
if you use foobar with very large libraries, the search becomes very slow.
If this could not be speed up, then at least the input should be non-blocking while searching after entering each letter.
Means if i type abcde actually it hangs after a, b, c, d and finally e.
What i prefer: The input textbox should react in realtime without noticed delay, so it does not feel that laggy, even if the list ist still being searched.
How big is this library?
If this could not be speed up, then at least the input should be non-blocking while searching after entering each letter...
What i prefer: The input textbox should react in realtime without noticed delay...
Advice: you should use Facets. No delay when typing a letter. Typing of two or more letters possible. (I use it with a very large library)
Where do you use an input textbox?
I reference to the standard search box in foobar2000 "Media library search".
How large is this library, I consider myself to have a big library and don't have the problems you describe.
about 120.000 files, over 600 gb, over 8000 folders.
I use quick search toolbar with a much larger library and the searchresults appear instant (<20ms).
my library index resides on a ssd
Yes, because quick search toolbar only searches after submitting the query string not after every key stroke. And your library is probably also quite small.
This doesn't matter for the search as the library will be completely loaded to memory on foobar2000 startup.
I can second that a small delay before the search actually fires would be welcome. The default search definitely gets pretty rough with a sizable library, with small freezes after each letter input. It gets better once there are less tracks returned due a longer, more specific search string.
One of the reasons I've been using the quicksearch component most of the time (although not the only) is the fact that you can adjust the delay.
quicksearch toolbar also has this "autosearch" feature, with configurable delay when it will start searching
thanks for clearing that up, did not know
ok a start delay would be another solution. but removing the delay from the input field (seperate thread/process) would be much more smooth if you do some "interactive" search while adding and removing letters.
like trying: Joe, Bannana then removing back to Joe, Banana it the old behaviour (no delay) should be kept. just the gui smoothness should be changed by some multithreading stuff... (the delegate... thing)
adding a delay after each letter which has to finish until the search occurs would drive me more mad (more than current behaviour) ;-)
Re: Change Request: Performance "Trick" on very large Libraries
to make it more clear what i thought:
you should use multiple processes/tasks/childs for library and playback.
so the player core will never stop playing if library is under heavy load and consuming the cpu power/time.
