Topic: lossyWAV can now run on POSIX systems natively (Read 3708 times) previous topic - next topic
Hello.
I managed to compile and run lossyWAV natively on GNU/Linux.
The small code changes I made should all be C++11-compliant or POSIX-compliant.
So, lossyWAV should theoretically also build successfully in other POSIX environments.
WARNING: I have near-zero experience with C++ and the Windows API. So, I take no responsibility for the code changes I made.
The code changes are available here:
https://github.com/MoSal/lossywav-for-posix
More like flossyWAV, amirite?
Nice work.
Many thanks, 2012 - your time and effort is much appreciated.
Very glad that you got it to compile and run natively!
LossyWAV is available for Arch Linux. https://aur.archlinux.org/packages/lossywav-git/
Cool.
If you add fftw to depends and use the fftw make target. You should get a slightly
faster binary (~6% faster for me with a Core 2 Due powered laptop).
And those changes in the PKGBUILD are already tested. Since I'm a longtime
Arch Linux user myself
All thanks should go to you and Tycho for making this possible.
