Topic: Binary Comparator version 2.0 (Read 16454 times) previous topic - next topic
Re: Binary Comparator version 2.0
Any plans for x64?
@loen
Binary Comparator
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Components_0.9/foo_bitcompare
> "Utilities > Bit-compare tracks..." from the context menu.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
how can you use it on foobar2000 newer versions? it says it is included but I cant see it. do I have to download a plugin or something?
Version 1.x needs to download the component. https://www.foobar2000.org/components/view/foo_bitcompare
The 2.0 betas have it already.
Hello. I'm trying to bind this plugin last version, but hot key not working, more trying to bind ABX Comparator 2.2.1 also not working!  My Foobar v 1.6.14.
MOD: link other topic
Bitcompare, like ABX, needs at least two selected tracks so there is something to compare against. A hotkey you set up for these functions will work just fine if you select two tracks and then hit the hotkey.
A this topic not must be in branch "3rd Party Plugins - (fb2k)"? Hello Case, have inmind through "ctrl" select two tracks? But from me this also not working. A mays make plugin by synchronized plays two and more playlists? At negative answer try create topic in worthy and corresponding branch!
MOD: edit per OP request
Reply #32
hey there, thanks for the awesome audio comparator taking gap offsets into account. I find it quite useful when i need to compare two audio tracks with different gap offsets - this tool helps to eliminate the difference caused from gap offsets and compare the actual audio.
now, on top of this, im not sure if this tool can be developed into something smarter, to be capable of doing things like:
1. when comparing two audios with different levels of track gain, to eliminate the difference caused by the gain levels and only to compare the real contents of the audio works? Or in other words, given two sets of audio tracks with different gain levels, first step to unify the gain levels, then do the comparison?
2. when comparing two audios with different play speed, to eliminate the difference caused by speed variances and compare the real contents?
I am not sure how valid and how niche these are. It's likely that we are not supposed to rely on binary comparison tools to make such comparisons. and instead, we should make use of more professional audio tools like Adobe Audition etc. to do so.
However, just wondering if there is any tools or methods that are as efficient to use as this binary comparator tool - without having to manually align the offsets/alter the gain levels/unify the play speed in professional audio tools; and be able to return a readable summary of comparison results like what binary comparator tool does.
Thanks for any thoughts/insights in advance!
