Topic: FLAC 1.3.1 has been released (Read 74766 times) previous topic - next topic
After 18 months of development, FLAC 1.3.1 has been released. The trigger for this release was a heap overflow found by the Google Security Team.
Changes
  • Huge encoding speedup for i386 and x86_64 (up to 250% for 24-bit)
  • Slightly improved compression of compression levels 6, 7 and 8
  • Fixed CVE-2014-9028 (heap write overflow) and CVE-2014-8962
  • Output buffer has been added to Windows to mitigate fragmentation
  • Various build system improvements and bug fixes
For the complete changelog, see http://xiph.org/flac/changelog.html
The source is available here, official Windows binaries are supplied here.
Don't forget to mention the added decoding efficiency improvements for all bit depths. Particularly 24 bit on IA32.
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
The website still points to the 1.2.1b binary. (Navigate to http://xiph.org/flac/download.html, then click the link named "FLAC for Windows (command-line tools only)."
I do notice that the 1.3.1 binary has just been added to the sourceforge page, but it still defaults to 1.2.1 ("Looking for the latest version? Download flac-1.2.1b.exe (2.7 MB)."
ktf thanks!
audiophool, give them some time
I'd be very interested to see an encoding speed comparison between 1.3.0 and 1.3.1 with one of the new Haswell based CPUs. They can make full use of the AVX2 improvements in the new version, many older CPUs only benefit from AVX1 or older SSE instruction sets.
Thank You very much for speed and compression improvements to all involved people.
Until now FLACCL was faster on my setup (strong CPU and week GPU) comparing to FLAC 1.3.0.
But now 1.3.1 is faster. Sticking with it.
is there plans for a patch/build to support old systems (xp sp3 barton 3000+) too?
Why, doesn't it work on that system?
Excellent work - thanks to all of the developers involved!
@ktf: i believe the cpu is missing a feature and the build relies on that? when trying to encode in foobar or flacdrop a grey error console showed up.
btw: the official 1.3.0 also did not work but i found a mingw version that did the trick.
AFAIK the build is build for i686, so at least MMX but no requirements for SSE. What error do you get? For 1.3.0, there have never been official binaries.
I benchmarked the official 1.3.1 (32bit) compile from xiph.org with other flac compiles I collected during its "evolution":
Encoder                   Options                     Process time    FLAC file size
flac 1.3.0                -8                          77.548 sec      292.407.249 bytes
flac 1.3.1                -8                          56.831 sec      292.127.317 bytes
flac-git-7251201 (AiZ)    -l 12 -b 4096 -m -e -r 6    50.887 sec      292.407.763 bytes
flac 1.3.1                -l 12 -b 4096 -m -e -r 6    52.572 sec      292.407.763 bytes
WAV file size = 663.678.612 bytes
CPU used: Intel Core 2 Quad Q9500 @ 2.8 GHz
AiZ's post: http://www.hydrogenaud.io/forums/index.php...st&p=869644
Although GCC 4.9.0 was used for AiZ's compile, it is faster (~ 3% on my CPU) than the GCC compiles of 1.3.1.
@AiZ: Would you mind to provide "your" 1.3.1?
Can I do a static build (flac & metaflac) on wheezy? If so, how?
Use
make LDFLAGS='-static'
to make a static build
Use
thanks (that did the trick).
Interesting, my own VS2013 compile is about 10 seconds slower than the official (gcc-compiled?) on the same set of 1.51GB of wav files.
I actually expected the opposite considering gcc is not "native" to windows.
I followed the readme instructions, so nasm.exe was used. How can I control which instruction sets are used, or does it try to automatically use all possible optimizations? I'm on an AMD Phenom II CPU.
FLAC doesn't use libraries for much of its work. The real work is done directly, so there isn't much difference between a native compiler and a non-native one.
This release uses function multiversioning, which is supported by GCC starting with release 4.9. IIRC, MSVC2013 supports it too, so it should indeed automatically check the CPU whether it supports the optimizations.
@ktf: maybe this is already helpful to you - cant test anymore (link broken), but i am pretty sure that it was even your 1.3.0 build that works on the barton cpu: http://www.hydrogenaud.io/forums/index.php...st&p=835599
regarding the specific error, i'll report back.
There's a line in configure.ac:
        XIPH_ADD_CFLAGS([-msse2])
which means that SSE2 is required.
Here is a build that doesn't need SSE2: (see post #39)
thats it, is working now, although very slow compared to the 1.3.0 build, thank you. would be interresting to see a sse1 version, as the cpu is capable of that instruction.
Really?
a) This build is able to use SSE/AVX-accelerated routines when possible.
b) Remember that -6, -7 and -8 presets were re-tuned. For example, -6 was very close to -5. Now it is noticeably slower but compresses better.
Or you can old presets by using the following settings:
old preset     equivalent settings
-6            -l 8 -b 4096 -m -r 6
-7            -l 8 -b 4096 -m -e -r 6
-8            -l 12 -b 4096 -m -e -r 6
This has just been fixed
It might also be worth pointing out that John33 has new Windows builds of 1.3.1 compiled with ICL 14 over at Rarewares
I've been using rarewares build for a while now, mostly because of the lack of official 1.3.0 builds for windows.
Now the question is, which one is faster / more efficient?
The Rarewares ICL x64 build is actually slower than the (official) GCC x64 build on my Haswell machine. Roughly 5% difference.
