Topic: Any recommendations for 24/96 => 16/44 => 24/96 for transparency (Read 22679 times) previous topic - next topic
Reply #50
(abx report snipped)
Total: 12/12 (0.0%)[/code]
The files are the ones from the thought experiment I described above: 20kHz tone vs. silence.
 sox -r 44100 -n -b16 b.wav fade h .1 3 .1 gain -6 stats
sox -r 44100 -n -b16 a.wav synth sine 20k fade h .1 3 .1 gain -6 stats
The new version of the ABX component behaves differently: at the the leading edge ("Set start") it's much better, at the trailing edge ("Set end") it's much worse.
What is the nature of the better and worse performance?
Reply #52
Both ABX plugins are making noises when I switch samples now so I cannot try to repeat the test. This was not the case when I did the previous ABX so I see it as valid.
If the ABX tool does not work well then the entire premise of this site is basically out the window so I suggest you guys fix it and at that time I would not mind trying to repeat the results!
I give up for now.
FLAC -> JDS Labs ODAC/O2 -> Sennheiser HD 650 (equalized)
Reply #53
There are other ABX tools. I'm not saying they're better (they have their own problems), but HA pre-dates fb2k (never mind fb2k's ABX component) by several years, and ABX itself pre-dates HA by decades.
David.
Reply #54
I give up for now.
"The ABX tool" is no longer a correct phrase (and hasn't been for decades) since there are literally dozens of different ABX  tools, both hardware-based and software-based.
This article directly or indirectly mentions about a half dozen different ones: http://en.wikipedia.org/wiki/ABX_test
None of them are perfect, but many are highly useful.
Sorry about your frustration, I'm sure that this little dust up will pass...
Reply #55
As the OP for this thread, I should mention that in the end I opted to use an easy to replicate file conversion and dithering methodology. I used SoX, with the following commands:
[blockquote]sox hirez.wav -b 16 temp_lowrez.wav -S rate 44100 dither -S
sox temp_owrez.wav -b 24 bottleneckedinhirezformat.wav -S  rate 96k[/blockquote]
My thanks go to Kees and other HA members for taking time to provide advice.
A short while ago I made a detailed post to AVS forum at #564 of AVS Forum > Audio > Audio Theory, Setup, and Chat > AVS/AIX High-Resolution Audio Test: Take 2. I provided download links for comparison files.
On the side topic, I personally find the design goal of the new (beta) ABX plug-in for foobar of permitting on-the-fly switching between A, B, X and Y, without producing a distinct interruption in the playback, a very desirable thing, provided it can be achieved without creating spurious clicks, etc.. I find it much easier to hear subtle differences if able to switch seamlessly.
