Amp power and current
Reply #189 – 2014-11-21 10:46:29
1. The power to the load is not defined by the rated power of the amp 2. The power to the load is defined by the voltage applied across the speaker terminals, the speaker efficiency and the speaker impedance 3. Thermal rating has nothing to do with sound quality at all. It is just a rating to tell one how close or far one is from overheating their speaker 4. The current through the load is defined by the load, not the amp, so it doesn't matter how large or how high current the amp is, so long as the amp is not clipping. 5. If an amp must supply 15 watts to hit a specific SPL in a room with a specific speaker, then whether the amp can supply 80 watts or 200 watts, the current to the load, will remain the same, at the same voltage, at 15 watts. Both amps are constrained by Ohms Law to supply the same power to the load, at the same voltage. Unless one exceeded the amps capabilities. 1. Yes. 2. To be strict, voltage and impedance only. (Efficiency tells you how good the speaker is at converting electrical into sound power. When you operate the speaker near the max. levels, the voice coil will heat up increasing speaker impedance. So the amount of power the speakers draws for a given voltage will go down. That's known as power compression.) 3. I'd call it power handling and due to the above effect (power compression), sound quality will actually suffer if you operate the speaker at this limit. 4. Yes. (I wouldn't say an "amp is high current", but "an amp that has high current output capabilities ". The load draws current as needed.) 5. Yes. (Although in some rare cases the amp has a high output impedance, which will result in the output voltage varying a bit with the impedance of the load. )
