Topic: AMIP - the complete now playing plug-in (Read 209226 times) previous topic - next topic
Reply #225
Dunno, try clean foobar installation, make new playlist, add songs to it, reinstall AMIP, start playing songs from playlist. See if the problem remains.
I can't reproduce it and you are the first to report such a problem. Something  wrong with your player configuration probably.
Reply #226
I have been using amip for a few years now with winamp but have recently switched to foobar and seem to be having a problem. Whenever I quote now playing information in mirc through amip from foobar, the artist and title are being guessed by the filename instead of being relayed from the ID3 tag.
I read through this thread and noticed someone mention a problem with shoutcast stream names not being updated and the solution was to disable a filename check through the configurator but I could find no such option to try.  I am aware that amip falls back on filename guessing when it cannot find an ID3 and that there are currently issues with foobar's use of ID3v2.4 so I converted the tags to ID3v1 but still experienced the problem.  I tried installing a fresh copy of foobar, amip, and mirc on a fresh copy of windows xp sp2 on a secondary machine but still experienced the problem.
The code I am using in mirc to pull the now playing information, which still works fine through amip through winamp is:
alias mp3 {
  if ($dde(mPlug,format,"%playing")) {
    /me $dde(mPlug,format,"now_playing:_%name_[%min:%sec~/%br~Kbps/%sr~KHz]")
  } else {
    echo Winamp is not currently running.
This string I'm using for the AMIP wrapper is:
%artist% - %title%
These are my software versions from my primary setup:
Windows 2003 v5.2 SP1 Build 3790
mIRC v6.16
AMIP v2.5.3.0
AMIP Configurator v1.6
AMIP Wrapper v0.90
Foobar v0.9.1
Could someone please confirm wether or not this is a bug (rename a random mp3 and see if it reports the name from your id3) or please let me know if I am missing something in the configuration somewhere? Thank You.
Reply #227
Solution and problem description is here.
You can find more information about id3lib and foobar id3v2 tags incompatibility in foobar forums here.
Reply #228
Thank you for your quick response. I saw this mentioned earlier in this thread however did not recognize it as pertaining to my problem, the phrasing in your other forum is much more clear.
I changed the %name to %s in my mirc script and now my problem is solved.
Keep up the good work!
Reply #229
Whats the var.. for streams(shoutcast radio)..
to show.. something like this
(Radio - DJ Something) (radio.url.com:8000)
*btw im only using aimp for foobar & mirc..
Reply #230
Try %s.
Reply #231
does it work with the latest vesion of yahoo messenger?
Reply #232
Yes, for me it works, but some other users have problems. I'll investigate it later.
Reply #233
I really like this plugin. Been using it to change my sigs dynamically.
However, just one minor quibble: Can you make the box to enter the %s in foobar2000 a multiline textbox? With all the HTML codes it emits it gets unwieldy long and I have to keep scrolling forward and backward.
Reply #234
I'll consider it, thanks for the suggestion.
Reply #235
New AMIP 2.53 beta (2006-07-24) build has been uploaded, minor changes only:
+ Option to keep song in clipboard (allows to disable clipboard restoring), you need latest AMIP Configurator
+ Change callback, called only on song change
Reply #236
AIMP seems to continually crash out foobar2000 for me... It is fine for the first track played, but as soon as foobar moves to the next track and starts playing it, it crashes out. Disabling AIMP stops it from crashing, and the crash dump shows it occurring in callback_run, in aimp.
I just want AIMP to write out the album, artist and track information to a file so I can display it using LCD Smartie, so I've got everything turned off except that, and the formatting string for writing out the file is "%1^lb%4^lb%2".
As foo_text seems to be down for the count for v0.9, and WinampSpam is limited to a single line of text, it looks like AIMP is my only chance.
Any suggestions?
Crash dump:
Illegal operation:
Code: C0000090h, flags: 00000000h, address: 06D60805h
Call path:
entry=>app_mainloop=>main_thread_callback::callback_run
Code bytes (06D60805h):
06D607C5h:  06 00 74 2D 55 8B EC 83 EC 08 83 E4 F8 DD 1C 24
06D607D5h:  F2 0F 2C 04 24 C9 C3 83 3D FC 22 E0 06 00 74 11
06D607E5h:  83 EC 04 D9 3C 24 58 66 83 E0 7F 66 83 F8 7F 74
06D607F5h:  D3 55 8B EC 83 EC 20 83 E4 F0 D9 C0 D9 54 24 18
06D60805h:  DF 7C 24 10 DF 6C 24 10 8B 54 24 18 8B 44 24 10
06D60815h:  85 C0 74 3C DE E9 85 D2 79 1E D9 1C 24 8B 0C 24
06D60825h:  81 F1 00 00 00 80 81 C1 FF FF FF 7F 83 D0 00 8B
06D60835h:  54 24 14 83 D2 00 EB 2C D9 1C 24 8B 0C 24 81 C1
Stack (0012F8A4h):
0012F884h:  011EDD80 7C9C93A0 77F643DD 7C9C93A0
0012F894h:  00000004 00000000 011ED28C 00000000
0012F8A4h:  00000000 00000032 00000000 00000000
0012F8B4h:  00000000 0147E9EC 00442E52 004DC9CC
0012F8C4h:  00000000 0012F960 0193CD58 00000000
0012F8D4h:  0012F8F0 0012F990 0012F910 77D618F4
0012F8E4h:  00000000 00000000 0147E9EC 00030000
0012F8F4h:  00000000 0131AE50 7FFDF000 00030000
0012F904h:  00000010 00000000 003C0000 0012F708
0012F914h:  0012F9CC 0012FA00 7C90EE18 7C9106F0
0012F924h:  FFFFFFFF 7C9106EB 004915DD 003C0000
0012F934h:  0012F99C 004A4F40 00000000 0040AA43
0012F944h:  0040AA58 004BE7EC 0040BB11 004428FB
0012F954h:  0147E9EC 004DC9CC 00000000 0012F9A8
0012F964h:  0043E464 004DC9CC 00000000 004BE7EC
0012F974h:  00163360 004BE7AC 10002D97 0016337D
0012F984h:  004BE7AC 00000022 004BE7EC 004DC9CC
0012F994h:  0012FA14 0012FA0C 0012FA00 004A7B5B
0012F9A4h:  FFFFFFFF 0012FA0C 00430F58 0012FA80
0012F9B4h:  0043100F 00000000 004BE7E0 01404428
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000032, EDX: 0CE9F9A7
ESI: 0147EA40, EDI: 0147E9E8, EBP: 0012F8B8, ESP: 0012F8A4
Crash location: "amip", loaded at 06C70000h - 06E1D000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F1000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D2000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 763B0000h - 763F9000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
focus                            loaded at 003D0000h - 003D8000h
kmw_dll                          loaded at 00B40000h - 00B5D000h
VERSION                          loaded at 77C00000h - 77C08000h
wow32                            loaded at 0FFB0000h - 0FFF5000h
appHelp                          loaded at 77B40000h - 77B62000h
ntvdm                            loaded at 0F000000h - 0F0A7000h
USERENV                          loaded at 769C0000h - 76A73000h
OLEAUT32                        loaded at 77120000h - 771AC000h
OLEACC                          loaded at 74C80000h - 74CAC000h
MSVCP60                          loaded at 76080000h - 760E5000h
tsappcmp                        loaded at 5B430000h - 5B440000h
foo_albumlist                    loaded at 00C90000h - 00CD1000h
foo_amipwrapper                  loaded at 00D00000h - 00D2C000h
foo_autoplaylist                loaded at 00D50000h - 00D80000h
foo_common                      loaded at 00DA0000h - 00DDA000h
foo_input_std                    loaded at 00E00000h - 00F0B000h
foo_playlist_manager            loaded at 00F30000h - 00F76000h
foo_pqview                      loaded at 00FA0000h - 00FBC000h
foo_run                          loaded at 00FE0000h - 0100B000h
foo_uie_albumart                loaded at 01030000h - 01062000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist                loaded at 010A0000h - 010DF000h
foo_uie_quicksearch              loaded at 01100000h - 01148000h
foo_ui_columns                  loaded at 01170000h - 0120B000h
foo_ui_std                      loaded at 01230000h - 01287000h
foo_utils                        loaded at 012B0000h - 012E9000h
dciman32                        loaded at 73BC0000h - 73BC6000h
amip                            loaded at 06C70000h - 06E1D000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
browseui                        loaded at 75F80000h - 7607D000h
gkh                              loaded at 01AE0000h - 01AF3000h
ALLCHR32                        loaded at 07650000h - 07661000h
SHDOCVW                          loaded at 77760000h - 778CF000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
WININET                          loaded at 771B0000h - 77256000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
browselc                        loaded at 20000000h - 20012000h
MpShHook                        loaded at 5F800000h - 5F815000h
MSVCR80                          loaded at 78130000h - 781CB000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
webcheck                        loaded at 74B30000h - 74B76000h
WSOCK32                          loaded at 71AD0000h - 71AD9000h
Secur32                          loaded at 77FE0000h - 77FF1000h
urlmon                          loaded at 77260000h - 77300000h
DSOUND                          loaded at 73F10000h - 73F6C000h
WINMM                            loaded at 76B40000h - 76B6D000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 00442E52h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004DC9CCh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 77D618F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004915DDh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004A4F40h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0040AA43h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0040AA58h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BE7ECh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0040BB11h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004428FBh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0043E464h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BE7ACh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 10002D97h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 004A7B5Bh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00430F58h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0043100Fh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BE7E0h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BBD2Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004E035Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BBD34h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004A584Dh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0043102Eh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D5E04Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042ECD6h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042F80Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BE37Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 004C55F8h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004208D0h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004C55DCh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004E2158h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0041005Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 1000E250h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000396Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+00000B5Ah)
Address: 10000000h, location: "shared", loaded at 10000000h - 1002A000h
Address: 004E21D8h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0044CAC9h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0040C5ADh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0040372Bh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004943AAh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004BE4D0h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004ACB62h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0042F9F8h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004DE970h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00494434h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0048F90Ch, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 0048F906h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004B29E8h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004B10F0h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004E21D0h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00494730h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 004ACF4Dh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 00493B94h, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 011ED15Ch, location: "foo_ui_columns", loaded at 01170000h - 0120B000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 00493BFDh, location: "foobar2000", loaded at 00400000h - 004F1000h
Address: 7C809A81h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualAlloc" (+00000000h)
Address: 7C801AD0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualProtect" (+00000000h)
Address: 7C809AA2h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualAllocEx" (+00000000h)
Address: 7C809AF0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualAllocEx" (+0000004Eh)
Address: 7C801A5Dh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualProtectEx" (+00000000h)
Address: 7C802367h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateProcessA" (+00000000h)
Address: 7C802332h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateProcessW" (+00000000h)
Address: 7C81DA9Eh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateProcessInternalA" (+00000000h)
Address: 7C8191EBh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateProcessInternalW" (+00000000h)
Address: 7C86114Dh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WinExec" (+00000000h)
Address: 7C810626h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateRemoteThread" (+00000000h)
Address: 7C81082Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateThread" (+00000000h)
Address: 7C862849h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "SetThreadContext" (+00000000h)
Address: 7C80220Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WriteProcessMemory" (+00000000h)
Address: 77D611E9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowsHookExA" (+00000000h)
Address: 77D5E4AFh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowsHookExW" (+00000000h)
Address: 71AB3E00h, location: "WS2_32", loaded at 71AB0000h - 71AC7000h
Symbol: "bind" (+00000000h)
Version info:
foobar2000 v0.9.3 beta 4
UNICODE
Additional info:
Common services 0.1  (foo_common)
Playlist Manager 1.0  (foo_playlist_manager)
AMIP Wrapper 0.90  (foo_amipwrapper)
Run services 0.3.2  (foo_run)
Album Art Panel 0.2.1  (foo_uie_albumart)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
FLAC decoder 1.1.0  (foo_input_std)
Default User Interface 0.9acc  (foo_ui_std)
Album List 3.2.0  (foo_albumlist)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Quick Search Toolbar 2.8f  (foo_uie_quicksearch)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Playlist tools 0.5.7  (foo_utils)
plugin.ini
[Advanced mIRC Integration Plug-In]
CFG_DISPLAYDELAY=0
CFG_TBIGNORECLASSES="#32770,Shell_TrayWnd"
CFG_MSN8=0
CFG_AIMSETSTATUS=1
CFG_SEARCH1="Title: $if2(%3,\(%3\) )%name $if2(%4,"%4") $if2(%7,[%7])"
CFG_MSNALT=1
CFG_RESTORECLIPBOARD=1
CFG_INDEXLIST=1
CFG_LASTENTRY=1
CFG_AIMSETPROFILE=1
CFG_SKYPEFORMAT="np: %name"
DDE_STRING="//describe $active np: %name [%min:%sec~m/%br~Kbps/%sr~KHz]"
CFG_DELETE=0
CFG_ENABLEIRC=0
CFG_QUEUETIMER=20
CFG_SEARCH3="Path: $if2(%fupdir,...\$trunc(%fupdir,15)\~)$if2(%fdir,$trunc(%fdir,15)\~)%nm"
Exceptions=""
CFG_TBF_FACE="Tahoma"
DDE_STRING3=""
CMD_STRING="/echo -s "
CFG_TBVS=0
CFG_RMICLIENT=0
CFG_SENDSKYPE=1
CFG_SENDGTALK=0
CFG_MSNTITLE="%2"
CFG_TBF_ITALIC=0
CFG_CHANGECB=""
Strip=0
CFG_RESTORE=0
DDE_STRING2=""
CFG_NOTIFY=0
CFG_LISTENERS=""
CFG_SFILE="C:\Documents and Settings\Alex\Local Settings\Temp\AIMP.txt"
CFG_SEARCH2="Time: [%min:%sec] [%br~kbps/%sr~kHz/%mode] $if($mat(%VBR,yes),VBR,CBR)$if2(%ENC, | %ENC)"
CFG_CHECKFILE=0
PasteHotkey="alt control z"
CFG_CUSTOM=0
CFG_CLIENTTO=1000
CFG_AIMHOST="127.0.0.1"
RegexHotkey="control j"
CFG_CAPTIONFORMAT="&func_cf(%name %?4<"%4"|>)"
CFG_AIMPORT=60335
CFG_USEENCSPOT=0
CFG_CLIENTPORT=60334
CFG_KLIENT=0
CFG_AUTOPLAY=1
Convert=0
CFG_STARTCB=""
CFG_DISABLETRANSPORTS=0
CFG_TBCUSTCOLOR=1
CFG_AIMSTATUSFORMAT="np: %name"
DDE_STRING1="//describe $active np: $if(%4,$if(%1,$if(%2,%1: $trunc(%4,32) - %2,%name),%name),%name) $if($mat(%min%sec,^0+$),[Stream],[%min:%sec])"
CFG_SENDYAHOO=1
CFG_LISTINDEXFORMAT="%d. %s"
CFG_DRAWONCAPTION=0
CFG_MAPPING=1
CFG_TBF_UNDERLINE=0
CFG_PACLIP="miranda32.exe&::&np: %name&::&key_down(0x11)^lbkey_down(0x0d)^lbkey_up(0x0d)^lbkey_up(0x11)"
CFG_RANDOM=0
DDE_SERVER="mIRC"
CFG_PAUSECB=""
CFG_RMIHOST="127.0.0.1"
CFG_SENDMSN=0
CFG_USECACHE=1
CFG_TBIGNOREPROCESSES="photoshop.exe,winamp.exe"
CFG_REPNL=1
CFG_RMIDISABLETIME=5
CFG_DDESERVER="mPlug"
CFG_TBCOLOR="000000"
Channels=""
CFG_STOPCB=""
CFG_EXT=0
CFG_PIRCH=0
CFG_AIMPROFILEFORMAT="I'm currently listening to "%name""
CFG_TIMERCB=""
CFG_CHARSET=0
CFG_TBF_BOLD=1
DoubleClickThreshold=1000
CFG_MSNALTFORMAT="$trunc(%name,100)%?4< [$trunc(%4,100)]|>"
CFG_PLAYSCB=""
CFG_TBCUSTFONT=0
CFG_DRAWUPDATE=0
CFG_PARSEDELAY=0
TMPS="//describe $active np: %name [%min:%sec~m/%br~Kbps/%sr~KHz]"
CFG_CHECKEXCLUDE="(^http://)|(\.(cue|zip|rar)$)"
CFG_SENDENTER=0
CFG_CLIENTHOST="127.0.0.1"
CFG_JCONF=0
CFG_RMIDISABLECOUNT=1
CFG_YAHOOFORMAT="np: %name"
CFG_ENABLEMAIL=1
CFG_SPAUSE="%1^lb%4^lb%2"
CFG_SHOWMSGONSTART=0
CFG_LEAVENUMLOCK=0
CFG_AIMREPLACESONG=0
CFG_EXITCB=""
CFG_RMIPORT=60333
CFG_NLREPCHAR=" / "
CFG_REPLACEPIPE=0
CFG_RMIENABLED=0
CFG_SPLAY="%1^lb%4^lb%2"
CFG_TBHS=0
CFG_MSNARTIST="%1"
CFG_UPDATEFILE=0
CFG_PLAYCB=""
DDE_UPDATE=1000
CFG_GTALKFORMAT="np: %name"
Enabled=0
CFG_SENDCONTROLENTER=0
CFG_HOT=0
CFG_SSTOP=""
CFG_IGNORE="(Connecting\.\.\.)|(Prebuffering "
CFG_DDEITEM="active"
CFG_MSNALBUM="%4"
CFG_DDETOPIC="COMMAND"
CFG_LASTPOS=20
DDE_STRING4="np: %name %?4<"%4"|>"
CFG_SEXIT=""
CFG_TBF_SIZE=10
CFG_PRESET=0
Reply #237
In your config
Enabled=0
It means that AMIP is disabled, it will not detect song changes, it will not parse song files, it will not write anything to your file in this state.
I've tried running AMIP with your plugin.ini and it doesn't crash no matter how many songs I play.
Are you sure it's not conflicting with any other plug-in? Can you reproduce this problem on a clean foobar installation (just foobar, default components and latest AMIP beta)?
Reply #238
Sorry, I copied that config after I'd already disabled it to stop it crashing, oops. The crashing config is the same, only with the Enabled checkbox checked.
I've tried removing the other components, then adding them back in one by one trying to find which one is interacting badly with AIMP. Of course none of them did, and now I am back with all my addins back in again, and no crashing. On the one hand, thats good news for me! It would have been nice to know why it crashed, but never mind.
If it starts doing it again, I will investigate further.
Alex
Reply #239
Still seems stable now, so still no idea what was causing the crash.
I do have another issue to raise, though, in that I discovered that AIMP was setting my Skype message to my now playing song. While I'm sure this might be what some people want, it isn't what I want, and having this enabled by default with nothing in the UI (either built in or configurator) to turn it off is hardly friendly! I had to look through the plugin.ini to find CFG_SENDSKYPE to disable it. While I was there I saw a few other integrations I could turn off too.
Is your Configurator falling behind? The latest I could find on your site was 0.21, although interestingly the manual shows what appears to be a v0.26 with features including UI for Skype integration.
Alex
Reply #241
Ah, excellent, that's just what I needed, thanks. You might want to put a note and a link next to the foobar download on your non-beta page that it needs the beta configurator, or only have the foobar download available on your beta page.
Alex
Reply #242
Hi everyone.
The site http://www.amip.tools-for.net seems to be unavailable since 24 hours.
Can someone please tell me if the site will be available again soon ?
And where can I download AMIP, AMIP Configurator and AMIP manual ?
Just FYI, I have LCDC software and the LCDC foobar plug-in. But this foobar requires AMIP to work. Here are its instructions :
foobar2000 plugin for LCDC, requires AMIP plugin for foobar for data
1) Download the latest beta AMIP plugin for foobar at http://www.amip.tools-for.net/config/
2) Download the "AMIP Configurator" also at http://www.amip.tools-for.net/config/
3) Install AMIP and Configurator
4) In the configurator select "Other Intergration -> Callbacks/Web".
5) In the "Play & Change" tab, add the text "/shmem(foobar2k_amip,delphi,update)"
6) In the "Timer" tab add the text "/shmem(foobar2k_amip,delphi,update)"
7) In the "Timer" tab add the text "/shmem(foobar2k_amip,delphi,clear)"
8) Okay/Save AMIP congifuration and close it
9) Now enable the plugin in LCDC, and all the data I can get should now be availble in LCDC.
Feel free to ask int eh forums if you have any questions.
Can somebody help ?
Many thanks in advance.
Regards,
Jose
Reply #243
hey there .. so I wanted to ask a question about amip ..
I was using winamp before and my amip worked just fine there .. so when I decided to finally get amip plugin for foobar as well , I cant get it to work .. installed the plugin , got the configurator .. and I think I set all the settings needed in the configurator .. but what I dont get is the amip box in foobar .. whats that good for ?
in winamp I was using the paste from clipboard method to get my songs to mirc ... any help would be greatly appreciated ...
Reply #244
Jose Hidalgo: there was a problem with Apache on the server while I was on the vacation, the server should work fine now.
Sten: not sure what is the problem, please clarify. AMIP wrapper settings in foobar are mainly to specify the format for %s AMIP variable using native foobar formatting.
Reply #245
is there a way to get only DLLs of AMIP ? I'm allergic of .exe installer for foobar plugins... (decrease the easyness to transport foobar on an external device, need a desinstaller to remove the plug-in, etc.)
other question, is the support of Google Talk done directly through the music statut of GTalk, or does it changes the normal user statut ?
all the best.
Reply #246
No, there is only installer download.
AMIP changes GTalk normal status text.
Reply #247
Im having some troubles with AMIP, when I upgraded to Windows Live Messenger AMIP stoped working, it can spam into any other program/field, but not in MSN conversations
Earlier versions of MSN have had the same problem, but if you installed MSN Plus it suddenly worked, but with the Live version it doesn't seem like it works...
I was wondering if anyone else has the same problem like me and if there's a solution to this problem?
Reply #249
Yep, seems to be rather common problem, read here for details: http://amip.tools-for.net/board/index.php?showtopic=38 .
The last post in the thread on your own forums made my day, now it works again  Restarting MSN did work, so now i hope I can get it to work all the time
Though its a very strange thing, Microsoft should send over the source to you so you can make it work without restart
