Topic: AMIP - the complete now playing plug-in (Read 207850 times) previous topic - next topic
A great one!
... If it only would read APEv2 tags on mp3s
A great one!
I'll consider your feature suggestion. Thanks.
Cool! Seems to be a complete tool, I'll check it out. Does player commands from mIRC work with foobar2000 to?
Yes, all the commands from AMIP documentation will work with fb2k. I've already found one bug with /dde mplug control ff and rew (5 sec forward/backward). Don't use them in the current version or player will crash. Fix will be available in the next version.
I just wanted to say... Thank you!!
AMIP 2.37 released:
Changes since 2.36
* Now distributing changelog for last 5 versions, complete changelog is available from the AMIP site
* Stream check using http:// should be not case-sensitive (Bug #1882)
* wa3 integration: do not strip http:// from file name => stream title change should now be properly recognized
+ fb2k integration: you can use %_playlist_number% in title format
* No more numbers in the playlist. Side effect: after each call to Search dialog local playlist will be reset
* Cleanups in Local playlist support code
* Playlist search now matches each part of keyword separated by space (space is considered as .*? regexp)
* If playing .cue file, do not check the file name change (Bug #1940)
* QCD integration: %sr should return KHz, not Hz
* fb2k integration: %sr should return KHz, not Hz
* fb2k integration: Fixed ff and rew commands
+ fb2k integration: Title format is now configurable from Foobar2k AMIP Wrapper options
Now you can use Foobar formatted string in AMIP (%s variable), string format can be changed in the AMIP Wrapper options.
Available from http://amip.tools-for.net
Is it possible to get a direct download link? On both DSL and cable your website is amazingly slow for me. I can't even get the download page to load
is amip working on 0.7beta versions ?
Not yet, I'll try to make the experimental version this weekend.
Since AMIP site hosting provider is experiencing problems with american Internet channel, it may be difficult to get AMIP from http://amip.tools-for.net .
I've put AMIP 2.38 to the mirror site:
http://www.rzone.ru/amip
Release 2.38 addresses the following issues:
* Typo in Quick Start fixed, added information about F keys and F12 key issue explanation
* Reworked clipboard integration code, fixed problem with unregistering hotkeys introduced in 2.37
can u make a compile for 0.7 please?
It needs a bit of work 'cause API is changed, you have to wait a couple of days.
Ok, guys... I've released AMIP compatible with 0.7 beta.
Please note that it requires Foobar 0.7 beta 12 or later.
Here is the link: http://www.rzone.ru/amip/
There are 2 versions:
amip_foobar.zip -> for Foobar 0.6x
amip_foobar07b.zip -> for Foobar 0.7 beta 12
I hope you already know where to get the fresh links for the player and SDK:
http://www.hydrogenaudio.org/forums/index....showtopic=10743
AMIP 2.39 released
Changes since 2.38:
+ APEv1 and APEv2 tags support (%1-%7)
+ Monkey Audio format information support (%br, %sr, %typ, %min, %sec, %sl, %ENC)
* Help updates, added new APE related variables and flags
* fb2k beta 0.7 integration: shuffle/repeat toggle support from AMIP
Someone asked for APE tags support? Enjoy it!
http://www.rzone.ru/amip/2.39/
amip_foobar07b.zip -> for Foobar 0.7 beta 13
Please report any problems and suggestions.
What about a quick guide on how to set this great thing up with Bersirc?
You need ddewrapper plug-in for Bersirc installed to make it support DDE exchange, in AMIP set up DDE Server to BERS and make sure that direct send option is disabled.
Actually there is a readme in the ddewrapper zip, you can get it here:
http://www.rzone.ru/amip/2.39/ddewrapper.zip
What do i have to do. That AMIP only shows the Title by pressing a hotkey?
For such questions there is a Quick Start section in AMIP help. RTFM!
Just to let you know, i'm using the following mirc script to access AMIP:
/s /dde mPlug format /say "&b&uTrack&p:_&c12%name&p_&b&uPosition&p:&c12_%pm:%ps&p_&b&uof&p&c12_%min:%sec&p_&b[&p&c12_%sr&p_&b&ukHz&p&c12_%br&p_&b&ukbps&p_&b]"
This worked fine in 2.25 i think it was - however in every later version i've discovered that the underscore/space relaplacement stopped working (no matter whether the option was ticked or not) - it simply outputs with the underscores in there.
It seems your code is wrong, the following code works for me:
/s /say $dde(mPlug,format,"&b&uTrack&p:_&c12%name&p_&b&uPosition&p:&c12_%pm:%ps&p_&b&uof&p&c12_%min:%sec&p_&b[&p&c12_%sr&p_&b&ukHz&p&c12_%br&p_&b&ukbps&p_&b]")
2 icehot: if you still want to use /dde mPlug format instead of $dde, you don't need to put underscores intead of sapces.
I've changed the code in one of the latest versions, so that underscores are replaced only in the variables, not in the whole preset string. But for $dde mplug format it is necessary to use underscores and they are replaced in any case.
