Topic: 24-bit vs. 16-bit Audio listening test (Read 22618 times) previous topic - next topic
I didn't see it mentioned here on hydrogen.
Archimago did a nice job preparing a simple test with offering files, collecting data and some conclusion!
INTERNET TEST: 24-bit vs. 16-bit Audio - Can you hear the difference?
Procedure
Results and more
It is a very ambitious and fun to follow project by a hobby music lover that deserves some compliment no matter what some fault-finders will cite.
Hey thanks for posting, I completed the test right around first announcement, and totally forgot to check in to see the results!
For completeness I did a lot of trials with varying equipment (even though i knew that i would personally not be able to tell them apart ha ha) and it was a lot of fun.
the results are exactly what most here would've guessed they should be...
Props to archimago for his efforts, his blog is getting better all the time and is always a fun read
Cool.  I was impressed by the cost of the systems being used!
Wow, this is really neat. Not surprised by the 50/50 results (what you'd call guessing), of course.
Thanks Archimago for carrying this out, will check out his blog. And thanks for letting us know, Wombat.
High confidence responses: 50%, 49%, 44% right.
"I hear it when I see it."
This just goes to show that Barry Diament's claims about 24/96 audio being insufficiently high resolution are unequivocally true
These participants should've had their wives or girlfriends take the test for them from in the kitchen or whatever other nearby room. I hear that's where the sweet spot is since they can always tell the difference.
Imo the test would be more useful if low and middle anchor would be included. 10 bits, 14 bits or similar. Both dithered and noise shaped.
Discussion thread about this test already closed by mods on SHTV, probably emotions running too high. Some of it is amusing.
Can You Hear the Difference @ SHTV
Why? the question was whether people can spot a difference between 16/44.1 and 24/96 audio, and the answer seems to quite clearly support the null hypothesis that there is no audible difference. A "low" anchor at 14 bit might have only embarrassed audiophiles even more.
..the question was whether people can spot a difference between 16/44.1 and 24/96 audio..
I think he kept the sample rate at 96, just changed the bit depth. At least that's how I read it.
The dithering process was basic. Using an older version of Adobe Audition (version 3.0.1), a flat triangular dither of 0.5 bits was utilized with settings as shown:
The sample rate was kept at 96kHz. These are very conservative settings and no advanced settings like noise shaping was utilized as featured in some of the "better" dithering algorithms like iZotope's MBIT+ or Weiss' POWr, etc. Adobe Audition again was used to convert the dithered 16-bit data back to a 24-bits container.
The 24-bit and (effective) 16-bit versions were randomly assigned as Sample A or B and files were enumerated 1 to 6 in the final package downloaded by the respondents.
Grant
    daglesj said: ?
        So erm how many of you here have speakers etc. that have a frequency range higher than 22Khz?
    Being able to hear those frequencies isn't the point. What happens in that area of the spectrum directly affects the fundamentals that we do hear.
That made my brain hurt..If the source frequencies above 20KHz affected the fundamentals in the audible range, then a 44.1kHz sample rate will capture and reproduce that affect because it exists in the audible range below 22kHz.. Ow...
Is it really that hard to understand that you don't have to reproduce a 30kHz tone to reproduce it's effects on the signal within the audible range? You captured those audible effects when you sampled the source.. OW!! Make it stop!!
Grant
    daglesj said: ?
No, don't you see?  The ultrasonic content has to be there in real time, otherwise the brain magic doesn't happen.  ;>
Did they bring up Oohashi et al at all?
Hehehe. Yes, if 14 bits with excelent quality dithering and noise shaping would be very hard (or even impossible for almost all people ) to spot so they would realize how it's hopeless trying to hear any tiny difference between 16 and 24 bits.
To have any effect during playback you need lots of energy up there... which just is not there unless you do lots of nonlinear processing (compression etc.).
Wow. If AA3 still works like CEP in this respect, that's not even proper dither. You need a dither amplitude of 1 for it to work properly.
Can anyone with AA3 check?
New file: 96kHz stereo 32-bit.
Generate tones: 1Hz, no modulation, only the fundamental, -80dB both channels, sine wave, duration 10 seconds.
Convert sample type: 96kHz, stereo, 16-bit, enable dithering, dither depth = 0.5 bits, triangular, no noise shaping.
Amplitude: amplify: +70dB
Listen to the result. If the dither was working, you'd hear continuous white noise. When I do the above, the white noise pulses, meaning the dither is broken.
If you do the above but with dither depth = 1.0 bits, you get continuous white noise at the end.
I'm not claiming the difference is ever audible, or even detectable with any normal audio source - but it's interesting that the test gave the best possible chance of detecting the 16-bit version by using no noise shaping and broken "dither".
David.
It's not broken, it is just that the amplitude of the dither is so low that you get a mix of dither noise and quantization error.
See also If stupid dither is already enough...
I tried several times to play with low dither and on normal music i can't tell the diffeence, sometimes even truncated. When you amplify silent parts you normaly hear noise and adding 0.5 does sound clean on these samples imho. Also choosing the lower amplitude may made it harder for cheaters on this test. So i suggested to use a low amount to exaggerate
btw. anyone can convince the SoX team to implement Dither Depth?
On an Italian forum they are talking about frequencies that you don't hear but have benefits on your body anyway so better to keep high quality lossy files or lossless ...and that's why ABX test are useless.
somewhere in a book they are talking about UV frequencies that you don't hear but help for vitamin D that have benefits on your body anyway so better to keep UV in our music... and that's why ABX tests are useless.
you were so close to making an actual point. if only one part of the argument had like ... any relation with the rest, then it might have been actual reasoning. reason is one of those nifty logic tricks you can use to convince people. better luck next time.
No, I know it's not computationally/algorithmically broken, but in the context of Lipschitz and Vanderkooy mathematically correct dither it's broken!
I didn't want to ever say so but this was my idea, Archimago wanted to use Noise Shaped dither at first  See also If stupid dither is already enough...
Wombat, I invented LossyWAV; you don't need to convince me that truncation can be inaudible
I love it when people excuse their inability to ABX the unABXable on a lifetime attending rock concerts.
My hearing is fine for my age, but poor for (say) an 18 year old. Even so, in many ways I find myself far more critical than I used to be. This is with audible differences below 15kHz though, not inaudible ones.
David.
I think that he was just relaying that ridiculous point, because it fits to "made my brain hurt".
I wonder if classical music is really the best for these tests. Classic recordings are often recorded with the mics standing far from the instruments, giving a rather undetailed sound IMO. I much prefer up close recordings. Like you find in jazz and pop music (excluding the overly loud recordings).
Not that I would expect a different outcome in this test. I just wouldn't pick classical music as example for the best recorded music.
For these kind of tests you need high dynamic range. Classical is possibly one of the genres with highest DR.
