Topic: foo_convolve - Impulse response convolver (Read 299753 times) previous topic - next topic
Re: foo_convolve - Impulse response convolver
Reply #150
Great plug Garf.  Is it a zero-latency design?  If no, is the clean audio path (Mix Adjust = 0%) latency compensated?  There is strong phase issue with my own impulses for (say) Mix = 50% (it's possible they need editing).
BTW, I'd also love it if I could use different impulses for each sample rate (in my case it's for headphone or room corrections).
Author of -Wavpack4Wavelab- and -CheckWavpackFiles-
Reply #151
I have downloaded the Convolver component, with the hopes of auditioning some IR guitar cabs, but I have no idea how to use it. It appears to be installed but I can't find any mention of it apart from the under the "Installed Components" window. Can anyone help me please?
Reply #152
Preferences > DSP > right panel > double clic
Reply #154
aliendough:  You might want to try the newer foo_dsp_convolver available here:  https://hydrogenaud.io/index.php/topic,85107.0.html
Has improvements over the other one and the settings are easily handled like most Foobar DSP's, i.e. add to the "Active" DSP component list and click the "..." button.
Reply #155
I tried to download the convolver plugin, but I don' t know how to inastall it. It appears in the list of componets but it is dark and I can't see Dsp in the list to the left.
Can anybody help me ?
Reply #156
Are you talking about foo_dsp_convolver as I linked to above?  Once you have downloaded foo_dsp_convolver.fb2k-component, go to your "Components" window in Foobar preferences, hit the "Install" button, and select the file.  Then "Apply" to restart.  Same as other standard components.  Then it will show up as "Convolver (gapless)" in your Available DSPs list.
Reply #157
I was talking of the standerd plugin. I have now succeded in installing it.
Reply #158
After installing the Convolver component & setting is as an active DSP, I am not hearing any difference.
Should I define an impulse file ?
If yes, which one & where can I get it ?
Should I also change the level adjust to something different than 0.0 dB ?
Reply #160
How does one route channels to and from the convolver.
For instance for Virtual Surround, each of the five audio channels (5.1  6 channel file) needs an IR for each ear, and all of them need to be mixed together for binaural 2 ch. output.
I would imagine there would be similar routing requirements for crossover type applications.
Reply #161
This convolver cannot process multichannel at all.
