Topic: foo_lnk seems not working 100% properly... (Read 1774 times) previous topic - next topic
Dear foosion,
I found that foo_lnk (http://www.foobar2000.org/components/view/foo_lnk) is not working in every scenarios. When I drag .lnk file or folder containing it into normal playlist, then everything seems to be fine. But .lnk files aren't recognized in autoplaylists - no matter if they point to file that is inside current autoplaylist ML Branch or outside of it. Additionally only .lnk files linking directly to music files are recognized - those which point to music folders (folders containing music files) aren't recognized.
Also even if you use them on normal playlists, then "open containing folder" context menu item does not work which is bit uncomfortable... It will be nice if whatever directory was opened - the one with .lnk file or linked file.
Is it possible to fix any of above problems?
No, due to the way foo_lnk hooks into foobar2000 it is not possible to overcome these limitations and make .lnk files fully transparent. Sorry.
