Topic: Cassette Audio Repair (Updated Thread) (Read 1481 times) previous topic - next topic
Original Thread
[attachment=7912:GG_Sample_Clip1.wav]
Since I obviously have no idea how to properly attach audio.
I assume you're interested in intelligibility and not high fidelity
[attachment=7913:GG_Sample_Clip1.mp3]
Does this help? This was just a quickie play around.
Audition 3 noise reduce 9dB, noise reduction level 85, 1/2 second FFT sample 4k points.
Here's a basic example of what you can do with Audacity:
[attachment=7914:GG_Sampl...y_tweaks.mp3]
- Deleted right channel, converted left to mono
- Ran noise reduction filter with default settings (created noise profile from approx. 0:32-0:35)
- Added a 6 dB EQ bump from 1kHz - 4kHz
- Manually reduced amplitude of the handling noises at the beginning
- Applied the compression filter (-16 dB thresh, 4:1 ratio, default attack/release)
Obviously, you can hear the noise reduction working (i.e. trying to do it's thing), but given the severity of the noise, I think that will always be a trade-off with Audacity's filter, although, again, I didn't adjust it.
