Topic: QDesign plans to patent bad audio quality (Read 3737 times) previous topic - next topic
Since they can't achieve good quality - they decide to spoil the signal so others can't be good either
Patent application US20020009000A1: Adding imperceptible noise to audio and other types of signals to cause significant degradation when compressed and decompressed
Country: US United States of America
Assignee: QDesign USA, Inc.
Published / Filed: 2002-01-24 / 2001-05-11
Application Number: US2001000854166
IPC Code: G11C 29/00;
ECLA Code: G06F1/00N7R2; G10L19/00; G11B20/00C; G11B20/00P; H04B1/66M;
U.S. Class: 365/200;
Priority Number: 2001-05-11  US2001000854166
2000-09-22  US2000000667345
2000-05-15  US2000000570655
2000-01-18  US2000000484851
2000-05-31  US2000000584134
Abstract:
Primarily in order to discourage compression of data of signals intended for interfacing with humans, such as those containing audio content, particularly music, and thus to discourage the unauthorized reproduction and distribution of such content, such as over the Internet, the signal data is modified in a manner that is normally not perceptible to humans when the signal is reproduced but which causes the signal to be significantly degraded in a manner that is perceptible if the signal is later compressed and decompressed. In one embodiment, an audio signal is modified directly in a manner that causes significant degradation of the signal if it is compressed and subsequently decompressed. In another embodiment, a compressed version of an audio signal is modified, as part of a process of compressing the signal, in a manner that allows a good quality signal to result from a subsequent decompression but which results in a significant, perceptible degradation if this decompressed signal is again compressed and decompressed.
Great.
Where would this kind of thing be applied? In addition to the copy protection mechanisms on Audio CDs?
Very nice... that must be the FINAL solution against piracy, haha. There's too much stupidity out there...
Well...  hate to say - but if you can't make codec good - try to make all others sound bad
edit...
And, what if codec has a VBR option?
couldn't help but throw together this when I heard this story:
Honestly I don't believe they can achieve success with music. May be with audio books, but not music. However are there any working sound samples. I would like to try them.
Ogg Vorbis for music and speech [q-2.0 - q6.0]
FLAC for recordings to be edited
Speex for speech
From the QDesign website:
"QDX by QDesign is the only digital audio format designed to be the ultimate in usability and quality."
Wow, to add artifacts to the signal but maintain the ultimate in quality? They must be very talented. LOL  We'll see how 'imperceptable' the noise they add is.
I think RIAA might be VERY interested in this... Though if labels start to utilize this, maybe audio community responds with special filters which try to remove that noise pattern.
But P2P music quality might drop even further.. not that it isn't enough horrible already.
Juha Laaksonheimo
Applying for a patent is not the same as getting one.  Having a patent is not the same as having your patented device ir process used.  Decades ago Columbia records was going to snip a tiny portion of the audio spectrum out of their LP's to keep something from happening.  Probably to discourage copying.  It was hooted down.
I think lots of folks, including our home-grown idiot Orrin Hatch, are trying to achive fame and fortune by throttling internet file-trading.  There is no solution yet.  When there is a "solution" there will probably be a way around it pretty quickly.  I am not worrying about any of this.  I am worried about the sky falling, however.
Nov schmoz kapop.
I think they are already doing it...The last couple of albums I read articles about had the loud factor maxed out.  Could I even tell if they introduced more "noise" and made it sound bad?
I doubt it.
That technology might be good to stop transcoding
The "imperceptible noise" protection probably involves compressing and decompressing the audio using their own encoder before printing the CD. There's no way an MP3 made from that source will sound good! Valefor, they might ask to use your front-end...
That's what I thought: half the people out there ripping and trading won't even notice if this process works because they're happy with 96kbps Xing already!
David.
