Topic: Mass m4a to mp3 conversion ? (Read 6032 times) previous topic - next topic
Hi
I want to use my GF's itunes library in Traktor, but can't do so unless install iTunes (no way !) or convert to mp3.
Is there a good (preferably free) utility which will do this ?
Preferably it should be able to search nested folders for mass conversion, rather than me having to direct it to each folder, one at a time (it's a 10 GB collection).
You should not convert lossy files.  Traktor says it supports AAC files, so I would just leave them as AAC.
I agree with the previous poster that it's better to avoid lossy-to-lossy transcoding.
On the Windows platform, Traktor requires QuickTime for AAC playback. This is somewhat surprising considering that Traktor requires Win 7 or later. And Win 7 or later support AAC playback out-of-the-box. I suggest you open a support request with NI, suggesting they remove this dependency on QuickTime.
In that case it's presumably just because Traktor needs the QuickTime library (the same that iTunes uses) to decode AAC. That is indeed a bit odd since Windows 7 decodes AAC out of the box.
I agree with not transcoding from AAC to MP3, it's not great for audio quality and unnecessary. Just install Quicktime but make sure it is not the default player for any format. QuickTime is essentially a big codec pack with a small player on top. It is often used by professionals to add some pro formats (such as ProRes 422 or Cinepak) that Windows doesn't support out of the box. Traktor will use the AAC decode library but you will never have to use or even see Quicktime yourself. Just forget it's there.
Every night with my star friends / We eat caviar and drink champagne
Sniffing in the VIP area / We talk about Frank Sinatra
Do you know Frank Sinatra? / He's dead
Point taken. I'll copy over the original iTunes library & and install Crapple's hideous bloatware.
I'll echo the others in that a lossy-to-lossy conversion is generally not recommended.. BUT if you still want to do it, Xrecode2 (http://xrecode.com/) can do this for you.
Or you can convert AAC files to WAV or FLAC if Traktor supports them. This requires more space but it will happen during editing/mixing audio in Traktor anyway, and this way you don't have to install QuickTime and won't lose quality.
