Topic: [Question] About "--merge-blocks". (Read 3018 times) previous topic - next topic
When I include the option "--merge-blocks" the following happens:
original md5: bfd5392eb5a146e806a13dc9622faf65
verified md5: df25d44ee06b70bc222fc73e1e8e4d49
MD5 signatures should match, but do not!
Is this normal? Or I shouldn't use "--merge-blocks"? I don't know...
Thank you! :)
MD5 signatures of what? The decoded audio or the entire encoded WavPack files? If the latter, of course they differ because you have just instructed the encoder to alter its format.
wavpack.exe -m --merge-blocks --blocksize=512 test.wav
wvunpack.exe -m -v test.wv
results in:
original md5:  00b0bff6862b518452b46ad994cbde11
unpacked md5:  00b0bff6862b518452b46ad994cbde11
verified test.wv in 1.04 secs (lossless, 27.38%)
Input file is 16 bit, stereo, 44.1kHz.
MD5 signatures of the raw pcm data. That output is from WavPack program.
results in:
Strange, it doesn't work here. I always get incorrect MD5:
blueknight@bk:~/Desktop/Audio/01$ wavpack -m --merge-blocks --blocksize=512 01.wav
WAVPACK  Hybrid Lossless Audio Compressor  Linux Version 4.60.1
Copyright © 1998 - 2013 Conifer Software.  All Rights Reserved.
original md5 signature: bfd5392eb5a146e806a13dc9622faf65
created 01.wv in 1.17 secs (lossless, 40.08%)
blueknight@bk:~/Desktop/Audio/01$ wvunpack -m -v 01.wv
WVUNPACK  Hybrid Lossless Audio Decompressor  Linux Version 4.60.1
unpacked md5:  122c4c1e400fe8de0bbbb4a4cf89e5cc
I just want to know if "--merge-blocks" cannot be used that way or it is some kind of bug. I'm using the Linux version, if that matters (noticed your "wavpack.exe").
Do you use 64-bit wavpack? Try 32-bit version.
Also you use old version (4.60.1). Maybe this bug was fixed in 4.70.0.
I will try to compile a 32-bit version...
I'm using the latest wavpack I built from source (got it from official website):
blueknight@bk:~/Desktop/Audio/01$ wavpack --version
wavpack 4.70.0
libwavpack 4.60.1
Maybe the libwavpack is old? Investigating...
EDIT: It seems I have the latest libwavpack here... If not, please let me know.
EDIT: It seems I had to disable shared when compiling, the shared library in my system is old... It is updated now:
blueknight@bk:~$ wavpack --version
wavpack 4.70.0
libwavpack 4.70.0
And now it works:
unpacked md5:  bfd5392eb5a146e806a13dc9622faf65
verified 01.wv in 0.98 secs (lossless, 38.95%)
Simple fix, LOL...
Thanks for helping! SOLVED!
