My typical usage scenario of this feature is the following: While listening to a song on my mobile player, I decide that I no longer want this song in a particular playlist, so I delete the file on my mobile player. After syncing, the song shows up in a specific playlist and I can change its tags (to remove it from autoplaylists) or search for it in all playlists and remove it from where I find it appropriate.
Well that's kinda what I was expecting. Just checked again, it works. I have an idea:
Example:
I sync my playlist and all the files are on my device. Now I listen to my playlist and dislike this one song. I am going to delete it on my device.
Next time I sync, I'd like to know which songs are no longer on the device and ask me if I want to remove them also from my playlist on my computer. Right now it just shows me which songs have been removed since last sync and resyncs these files as well. Or did I miss some check box somewhere?
Please post the dump file here or via pm to me.
So, converting flacs that are not in cue sheets works? Is the cue sheet located at a network path or something like that?
Actually it seems like normal flac-files aren't working as well. It just crashes. Might have not realized that last time.
I am using these encoder options in your settings: "c:\program files (x86)\foobar2000\codec\lame.exe" -b 320
Not sure how to add files: failure_00000003.txt Or do you need the dmp-file?
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 72D5D5E0h
Access violation, operation: read, address: 77C5A5E7h
Last win32 error: 38
Call path not available.
Code bytes (72D5D5E0h):
72D5D5A0h: C7 2B C1 0F BE 4C 24 13 51 8B FE E8 00 EA FF FF
72D5D5B0h: 8B 16 8B 12 6A FF 8D 44 24 3C 50 8B CE FF D2 FF
72D5D5C0h: 45 0C 8B 5D 0C E9 7F 00 00 00 8B 44 24 14 8B 70
72D5D5D0h: 04 83 C0 04 89 44 24 14 8B C6 8D 58 01 8D 49 00
72D5D5E0h: 8A 08 40 84 C9 75 F9 2B C3 3B F8 76 28 2B F8 74
72D5D5F0h: 24 0F BE DA 8D 54 24 28 8B CB E8 C1 FB FF FF 85
72D5D600h: C0 74 0F 8B 4D 08 8B 11 8B 12 50 8D 44 24 2C 50
72D5D610h: FF D2 4F 75 DF 8B 4D 08 8B 01 8B 10 6A FF 56 FF
Stack (0B37F340h):
0B37F320h: 00C00000 0B37F3FC 1010D6B0 FFFFFFFF
0B37F330h: 0B37F3B8 72D5D648 0B37F370 00000001
0B37F340h: 101167B0 0B37F414 079D10C8 0000004A
0B37F350h: 2037F49C 0B37F414 10006BB5 10006D21
0B37F360h: 0000004A 10116B74 10116B48 0B37F380
0B37F370h: 10006C20 0B37F38C 10006BB5 00CCCCCC
0B37F380h: 0B37F398 10006ED7 00000000 00000041
0B37F390h: 0B37F6F0 00000041 0B37F3B0 100066DD
0B37F3A0h: 00000041 00000004 00000039 079BB648
0B37F3B0h: 00000004 0B37F3D4 0B37F3CC 72D59E24
0B37F3C0h: 0B37F3E8 101167FA 0B37F414 0B37F408
0B37F3D0h: 10017933 0B37F3E8 101167B0 0B37F414
0B37F3E0h: 0B37F6F0 0B37F414 101169D4 079BBF68
0B37F3F0h: 0000004A 00000080 00000049 0B37F6F0
0B37F400h: 1010E7AA 00000000 0B37F6FC 10043BD8
0B37F410h: 101167B0 77C5A5E7 0B37FE70 0B37F728
0B37F420h: CCCCCCCC CCCCCCCC CCCCCCCC CCCCCCCC
0B37F430h: CCCCCCCC 01CCCCCC 0B37F408 032A1D40
0B37F440h: CCCCCCCC CCCCCCCC CCCCCCCC CCCCCCCC
0B37F450h: CCCCCCCC CCCCCCCC 0B37F408 CCCCCCCC
Registers:
EAX: 77C5A5E7, EBX: 77C5A5E8, ECX: 0B37F300, EDX: 00000020
ESI: 77C5A5E7, EDI: 00000000, EBP: 0B37F3B8, ESP: 0B37F340
Crash location:
Module: shared
Offset: D5E0h
Symbol: "CreateFileAbortable" (+2A1Bh)
Loaded modules:
foobar2000 loaded at 00850000h - 00A1F000h
ntdll loaded at 779B0000h - 77B2B000h
KERNEL32 loaded at 753F0000h - 754D0000h
KERNELBASE loaded at 74D60000h - 74EDE000h
SHLWAPI loaded at 757A0000h - 757E5000h
msvcrt loaded at 754D0000h - 7558E000h
combase loaded at 751C0000h - 7537D000h
COMCTL32 loaded at 73520000h - 7372F000h
RPCRT4 loaded at 75690000h - 7573D000h
WINMM loaded at 73880000h - 738A4000h
DSOUND loaded at 737F0000h - 73876000h
GDI32 loaded at 757F0000h - 7593F000h
SspiCli loaded at 74600000h - 7461E000h
USER32 loaded at 74620000h - 74767000h
CRYPTBASE loaded at 745F0000h - 745FA000h
bcryptPrimitives loaded at 74D00000h - 74D58000h
sechost loaded at 74FF0000h - 75034000h
ADVAPI32 loaded at 75E70000h - 75EEB000h
SHELL32 loaded at 76300000h - 776FF000h
cfgmgr32 loaded at 75050000h - 75087000h
powrprof loaded at 777A0000h - 777E4000h
windows.storage loaded at 74800000h - 74CF9000h
kernel.appcore loaded at 75940000h - 7594C000h
UxTheme loaded at 73760000h - 737D5000h
shcore loaded at 77710000h - 7779D000h
WINMMBASE loaded at 73730000h - 73753000h
profapi loaded at 75380000h - 7538F000h
ole32 loaded at 759D0000h - 75ABB000h
CRYPT32 loaded at 75CF0000h - 75E68000h
MSASN1 loaded at 75C90000h - 75C9E000h
zlib1 loaded at 62E80000h - 62E9F000h
shared loaded at 72D50000h - 72D7D000h
Secur32 loaded at 73D70000h - 73D7A000h
WINHTTP loaded at 74330000h - 743CB000h
gdiplus loaded at 72D80000h - 72EEB000h
imagehlp loaded at 74FC0000h - 74FDB000h
COMDLG32 loaded at 75590000h - 75682000h
FirewallAPI loaded at 74770000h - 747CE000h
dbghelp loaded at 731C0000h - 732FF000h
NETAPI32 loaded at 759B0000h - 759C3000h
dbgcore loaded at 73070000h - 73091000h
DAVHLPR loaded at 737E0000h - 737EB000h
IMM32 loaded at 747D0000h - 747FB000h
fwbase loaded at 72D20000h - 72D4C000h
MSCTF loaded at 777F0000h - 7790F000h
dwmapi loaded at 73050000h - 7306D000h
foo_onewaysync loaded at 10000000h - 10163000h
OLEAUT32 loaded at 75090000h - 75122000h
MSVCP110 loaded at 72C90000h - 72D15000h
MSVCR110 loaded at 72770000h - 72846000h
mfc110u loaded at 72850000h - 72C8F000h
foo_dsp_std loaded at 72720000h - 72762000h
foo_cdda loaded at 726C0000h - 72711000h
foo_unpack loaded at 72670000h - 726BC000h
foo_converter loaded at 725E0000h - 72668000h
foo_ui_std loaded at 724D0000h - 725DE000h
MSIMG32 loaded at 724C0000h - 724C6000h
foo_freedb2 loaded at 72470000h - 724C0000h
foo_fileops loaded at 72420000h - 7246E000h
foo_rgscan loaded at 723B0000h - 72411000h
foo_input_std loaded at 72250000h - 723AB000h
avutil-fb2k-54 loaded at 721A0000h - 7222A000h
avcodec-fb2k-56 loaded at 71FC0000h - 7219E000h
MSACM32 loaded at 72230000h - 72248000h
foo_httpcontrol loaded at 71F40000h - 71FB4000h
WS2_32 loaded at 75AC0000h - 75B1F000h
MPR loaded at 71F20000h - 71F36000h
WSOCK32 loaded at 71F10000h - 71F18000h
foo_playcount loaded at 71ED0000h - 71F0E000h
foo_albumlist loaded at 71E70000h - 71ECB000h
foo_audioscrobbler loaded at 04DE0000h - 04E13000h
foo_dsp_eq loaded at 71E30000h - 71E67000h
foo_out_wasapi loaded at 04EE0000h - 04F09000h
WindowsCodecs loaded at 71CB0000h - 71E23000h
clbcatq loaded at 75130000h - 751B4000h
dataexchange loaded at 71C60000h - 71CA1000h
d3d11 loaded at 71990000h - 71BAA000h
dcomp loaded at 71BB0000h - 71C57000h
dxgi loaded at 71900000h - 71983000h
twinapi.appcore loaded at 71830000h - 718FD000h
bcrypt loaded at 74550000h - 7456B000h
sud loaded at 71790000h - 7182E000h
ADVPACK loaded at 71760000h - 7178C000h
PROPSYS loaded at 73DD0000h - 73F1B000h
DUI70 loaded at 715F0000h - 71757000h
SETUPAPI loaded at 75EF0000h - 762FB000h
VERSION loaded at 745E0000h - 745E8000h
mswsock loaded at 742E0000h - 7432F000h
PortableDeviceApi loaded at 6ED90000h - 6EE13000h
explorerframe loaded at 6E950000h - 6ED8A000h
edputil loaded at 6E900000h - 6E949000h
DEVOBJ loaded at 744F0000h - 74512000h
PortableDeviceTypes loaded at 6E8D0000h - 6E8F8000h
WINTRUST loaded at 75CA0000h - 75CE2000h
Stack dump analysis:
Address: 101167B0h (foo_onewaysync+1167B0h), symbol: "foobar2000_get_interface" (+EEED0h)
Address: 10006BB5h (foo_onewaysync+6BB5h)
Address: 10006D21h (foo_onewaysync+6D21h)
Address: 10116B74h (foo_onewaysync+116B74h), symbol: "foobar2000_get_interface" (+EF294h)
Address: 10116B48h (foo_onewaysync+116B48h), symbol: "foobar2000_get_interface" (+EF268h)
Address: 10006C20h (foo_onewaysync+6C20h)
Address: 10006ED7h (foo_onewaysync+6ED7h)
Address: 100066DDh (foo_onewaysync+66DDh)
Address: 72D59E24h (shared+9E24h), symbol: "uPrintfV" (+11h)
Address: 101167FAh (foo_onewaysync+1167FAh), symbol: "foobar2000_get_interface" (+EEF1Ah)
Address: 10017933h (foo_onewaysync+17933h)
Address: 101169D4h (foo_onewaysync+1169D4h), symbol: "foobar2000_get_interface" (+EF0F4h)
Address: 1010E7AAh (foo_onewaysync+10E7AAh), symbol: "foobar2000_get_interface" (+E6ECAh)
Address: 10043BD8h (foo_onewaysync+43BD8h), symbol: "foobar2000_get_interface" (+1C2F8h)
Address: 101138E8h (foo_onewaysync+1138E8h), symbol: "foobar2000_get_interface" (+EC008h)
Address: 10125190h (foo_onewaysync+125190h), symbol: "foobar2000_get_interface" (+FD8B0h)
Address: 1010A41Fh (foo_onewaysync+10A41Fh), symbol: "foobar2000_get_interface" (+E2B3Fh)
Address: 10030349h (foo_onewaysync+30349h), symbol: "foobar2000_get_interface" (+8A69h)
Address: 1004E520h (foo_onewaysync+4E520h), symbol: "foobar2000_get_interface" (+26C40h)
Address: 10108BA9h (foo_onewaysync+108BA9h), symbol: "foobar2000_get_interface" (+E12C9h)
Address: 1004DFB8h (foo_onewaysync+4DFB8h), symbol: "foobar2000_get_interface" (+266D8h)
Address: 1010B1C0h (foo_onewaysync+10B1C0h), symbol: "foobar2000_get_interface" (+E38E0h)
Address: 1004E52Bh (foo_onewaysync+4E52Bh), symbol: "foobar2000_get_interface" (+26C4Bh)
Address: 754038F4h (KERNEL32+138F4h), symbol: "BaseThreadInitThunk" (+24h)
Address: 754038D0h (KERNEL32+138D0h), symbol: "BaseThreadInitThunk" (+0h)
Address: 77A156C3h (ntdll+656C3h), symbol: "RtlUnicodeStringToInteger" (+253h)
Address: 74E9F2F0h (KERNELBASE+13F2F0h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 77A2EC80h (ntdll+7EC80h), symbol: "wcstombs" (+90h)
Address: 72CD5FC3h (MSVCP110+45FC3h), symbol: "Xp_subx" (+BF1Dh)
Address: 77A1568Eh (ntdll+6568Eh), symbol: "RtlUnicodeStringToInteger" (+21Eh)
Address: 77A3B6D2h (ntdll+8B6D2h), symbol: "RtlCaptureContext" (+E2h)
Address: 00905A4Dh (foobar2000+B5A4Dh)
Address: 72676F72h (foo_unpack+6F72h)
Address: 10000000h (foo_onewaysync+0h)
Address: 7273722Eh (foo_dsp_std+1722Eh), symbol: "foobar2000_get_interface" (+51EEh)
Environment:
App: foobar2000 v1.3.9
UI: Default User Interface 0.9.5
Components:
Core (2015-11-02 13:34:32 UTC)
foobar2000 core 1.3.9
foo_albumlist.dll (2015-11-02 13:31:02 UTC)
Album List 4.5
foo_audioscrobbler.dll (2010-06-04 07:27:04 UTC)
Audioscrobbler 1.4.7
foo_cdda.dll (2015-11-02 13:30:24 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2015-11-02 13:30:32 UTC)
Converter 1.5
foo_dsp_eq.dll (2015-11-02 13:30:52 UTC)
Equalizer 1.0
foo_dsp_std.dll (2015-11-02 13:30:38 UTC)
Standard DSP Array 1.3.1
foo_fileops.dll (2015-11-02 13:30:04 UTC)
File Operations 2.2.1
foo_freedb2.dll (2015-11-02 13:30:14 UTC)
Online Tagger 0.7
foo_httpcontrol.dll (2013-04-26 16:12:30 UTC)
HTTP Control 0.97.14-fb2kc
foo_input_std.dll (2015-11-02 13:34:32 UTC)
Standard Input Array 1.0
foo_onewaysync.dll (2015-12-14 04:19:12 UTC)
One Way Sync 0.5.4
foo_out_wasapi.dll (2015-07-30 15:12:24 UTC)
WASAPI output support 3.2.3
foo_playcount.dll (2013-02-01 08:40:46 UTC)
Playback Statistics 3.0.2
foo_rgscan.dll (2015-11-02 13:31:02 UTC)
ReplayGain Scanner 2.2.2
foo_ui_std.dll (2015-11-02 13:34:32 UTC)
foo_unpack.dll (2015-11-02 13:30:38 UTC)
ZIP/GZIP/RAR Reader 1.7.1
Recent events:
Pre component load
Loading DLL: C:\Users\xxxx\AppData\Roaming\foobar2000\user-components\foo_onewaysync\foo_onewaysync.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_dsp_std.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_cdda.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_unpack.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_converter.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_ui_std.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_freedb2.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_fileops.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_rgscan.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_input_std.dll
Loading DLL: C:\Users\xxxx\AppData\Roaming\foobar2000\user-components\foo_httpcontrol\foo_httpcontrol.dll
Loading DLL: C:\Users\xxxx\AppData\Roaming\foobar2000\user-components\foo_playcount\foo_playcount.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_albumlist.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_audioscrobbler.dll
Loading DLL: C:\Program Files (x86)\foobar2000\components\foo_dsp_eq.dll
Loading DLL: C:\Users\xxxx\AppData\Roaming\foobar2000\user-components\foo_out_wasapi\foo_out_wasapi.dll
Components loaded in: 0:00.342442
Pre config read
Configuration read in: 0:00.024128
Starting playlist loading
Watching: D:\j-Music
Watching: D:\Downloads
Album List refreshed in: 0:01.474585
User Interface initialized in: 0:01.531490
Processing commandline
initquit::init entry
initquit::init exit
Startup time : 0:02.216026
foo_ows: Syncing 'New Playlist' to wpd:\Xperia Z2\SD-Karte\MusicTest\%artist%\%album%\%title%.$ext(%_path%)
Machine specifications:
OS: Windows 6.3.9600 x64
CPU: IntelĀ® Core i7-3770K CPU @ 3.50GHz, features: MMX SSE SSE2 SSE3 SSE4.1 SSE4.2
CPU threads: 8
Audio: YAMAHA RX-V775 (4- NVIDIA High Definition Audio); DELL U2412M-0 (3- NVIDIA High Definition Audio); DELL U2412M-3 (NVIDIA High Definition Audio); Lautsprecher (2- Logitech G930 Headset)
Also your plugin does not seem to work when Windows Mediafeatures such as Windows Media Player are deactivated. I had to reactivate it and reboot my computer to get this working.
