Topic: foo_onewaysync (Read 11460 times) previous topic - next topic
foo_onewaysync
This component helps you keep your portable mp3 player in sync with foobar playlists. It automatically converts files with the encoder of your choice, copies foobar playlists and files with a single menu command.
Help and Discussion Thread
edit: uploaded new version 0.5.4
foo_onewaysync
I've uploaded a new version which adds the option to convert lossy files as well. The file types can be specified in the preferences.
foo_onewaysync
-fixed: menu command, no playlists selected lead to div by 0
-fixed: context command, choosing playlist export lead to crash
-fixed: multiple listing in installed components view
foo_onewaysync
Changes in version 0.2.6:
-improved: finding existing converted lossy files after move and rename
-improved: adding new folders and titleformat scripts is now more convenient
foo_onewaysync
Changes in version 0.2.8:
- converted files are no longer stored at source location by default, needs to be enabled in preferences
- minor fixes
foo_onewaysync
Changes in version 0.2.9:
- avoid converting files when unnecessary
- improved metadata syncing
credits to yeeeargh for testing!
foo_onewaysync
using Linux/Wine and I can't properly send tracks as it crashes. How do I correcntly configure the file-folder structure?
foo_onewaysync
In linux vs. Windows file-folder structure is path'd by '/' not '\'
e.g.
~/E/Music/album1
vs.
~\E\Music\album1
because WINE doesn't read linux file system you'll have to use these drive letters that WINE offers to navigate files.
foo_onewaysync
Changes in 0.5.4:
new
- enable different encoders
- MTP storage devices support
- track device target for removed files
- conversion multi-threading
- copy lyrics files
- multiple commands per device
- copy other files when syncing
fixed
- copy cover art
- no more unnecessary file conversions
- process files with script
- cue sheets are handled properly now
- file conversion of multichannel audio
known issues
- for MTP devices: tags of preexisting files are not updated, this is not a bug
Download
Re: foo_onewaysync
New release 0.5.5!
new
- support more encoders
- option to delete unreferenced files from device
- option to generate playlists with linux compatible paths
- should work in environment without WMP such as Wine (MTP not supported)
- static linking, no further dlls required
- bug fixing
Re: foo_onewaysync
Test version with enhanced diagnostic info for people with MTP issues
Re: foo_onewaysync
New release 0.5.6
Changes:
- hopefully fixed MTP for everyone
- enable multiple cover art files (enter as comma separated list)
- workaround for issue with mono files
- fixed minor regressions
