Topic: broken lame header (Read 3395 times) previous topic - next topic
broken lame header
hi.
i've got a small problem using eac + lame.
today i was encoding a few albums and i noticed that EVERY LAST TRACK on the album had a broken header.
it was recognised as "fhg" 32kbps [cbr].
but my settings were diffrent (--alt-preset fast standard  %s %d)
what's wrong ?!
thnx for info.
broken lame header
additional info.
i was wrong. not every last file on an album has a broken header.
it just happens. sometimes even 2 or 3 files are 'broken'.
:confused:
broken lame header
Are you using ID3v2 tags?
Sometimes, when adding ID3v2 tags, EAC removes some bytes in the beginning of the file. (At least, that's what I heard. Never happened to me, because I don't use ID3v2)
Regards;
Roberto.
broken lame header
you're probably right... that might be the cause.
i must check if it was mentioned on EAC forum.
thnx.
broken lame header
I had the same problem - unchecked ID3v2 in EAC options and it's OK now (must use a tagger for longer titles, tho). But You can always use VBRfix for broken VBR headers
broken lame header
thnx for the tip !!!
