Topic: Opus and replay gain (Read 36636 times) previous topic - next topic
If the output gain is the Album Gain, but the player developer and/or the user doesn't understand the significance of this, then Opus files will play back about 15dB quieter than mp3s (both ripped from the same 2014 CD), and there's nothing the user can do about it.
Consider this scenario for a second here. You're assuming the user has (1) ReplayGain tagged Opus files yet no understanding that they are...from what source would those appear exactly? (2) MP3 files that are not ReplayGain tagged or a player that doesn't have ReplayGain support.
This scenario is identical to someone CURRENTLY plugging ANY ReplayGained file into a player that DOES support ReplayGain and wondering why it's quieter than his other files.
So you're preaching doom over a scenario that already exists outside Opus.
How soon before someone writes a tool to batch re-set the output gain on a bunch of Opus files to 0, or creates a player that ignores the output gain by default (hence breaking the Opus spec)?
In both of these cases, they'll learn why the gain is there, and there's good chances that they offer a proper option for it. So a win in my book.
If you know that playing at the right loudness will cause clipping, there's no right way to play back the music.
You know there are two ways to mitigate this.
And they both suck, hence "no right way to play back the music" in that case.
can never have the "just play it a bit quieter but without damaging the audio" option.
Unfortunately this (peak normalization) isn't actually very good at totally preventing clipping in practice, and you're losing the benefit of ReplayGain in the first place when doing so. So no, I don't think it's worth it.
This makes no sense. If you called the Output Gain "Album gain", specified that it was either absent or correctly filled by the encoder, specified that every player must apply it by default (they can add a user option to disable it if they want), and also included peak information - then you'd have exactly the benefits that you seek, but avoid most of the drawbacks. Specifically, not including peak information isn't a required step to get to where you seem to want to. It's not a necessary cost. It's a pointless mistake.
Adding complexity to a system is always a cost. Your description is just "I want a pony", and terribly non-constructive. What was designed in Opus is a system that will bring the benefits of ReplayGain (sans clipping prevention, which I believe to be senseless and would have required player support) to every player, even if they have no ReplayGain support. This is a huge win over the situation with Vorbis.
First, how could one add accurate peak information to Opus files knowing that decoders don't produce bit-exact output?
All fields can be filled with bogus values including ReplayGain tags. So all solutions will depend on non-100%-dependable assumptions anyway.
If I was presented with this problem as a developer, I would:
1- Use -23LUFs (as default) globally for consistency.
2- Ignore ReplayGain tags if Opus gain is set.
3- If Opus gain is not set, respect ReplayGain tags even if their values are probably inaccurate.
Note: ReplayGain tags in OGG Opus files will probably be the result of tag copying. So their values wouldn't be accurate as the operation was lossy and Opus decoders are not bit-exact.
It is a relatively simple task to copy across Vorbis Comment tags of any sort from Flac or Ogg files into Opus files and plenty of tools will do that for you.  They are not gains calculated for the Opus file but closer than anything else available to most people.  So if they occur I'm going to at least give the option to respect them.  There is a reference Opus gain tool under development, but I haven't checked in to see where that it at.  Right now the only place I see non-zero Opus output gains is on some streams.  And not others!  Respecting them causes violent loudness swings between different streams, exactly the situation that replay gain is intended to avoid.
More importantly seems to be the attitude that the Opus standard should be respected in its entirety wrt gain.  That is simply unworkable in a music player.  While "just works" is a laudable goal, in this case it is "just works for most people that don't care".  The standard says the output gain must *always* be applied.  The suggestion is that it *may* be an album gain, or it may not.  How can a gain that *must always* be applied be an album gain?  What if someone doesn't want an album gain, or any volume correction gain?  If the output gain was an album gain then it should be ignored, but if it isn't an album gain then there is no album gain.  I appreciate that the codec was not developed with audiophile players at the head of the customer list, but it is simply broken in this respect.
As for peaks and scaling, I'm not a huge fan of it.  Apart from anything else, it just messes up the rest of the replay gain adjustments, often for no good (ie. audible) reason.  Still, if the tags exist (with compatible gain tags) I will at least give the option to apply them.  Good music players offer the option of peak scaling or not and I don't see any reason not to respect that decision using the best information I have available.
Garf, I know you get pleasure from arguing things, and I know it would make life easier if the Opus spec was right on this, but it simply isn't. Your arguments that it's all fine are totally unconvincing...
I think most people have audio files that they didn't create themselves. I bet the majority of audio files in the world are in the hands of people who didn't create them.
It's far from identical because there's one critical difference: In most players, ReplayGain is off by default until you switch it on. In Opus players, Output Gain is applied by default (and usually non-defeatable).
So no one hit this problem before, unless they intentionally switched ReplayGain on. Whereas with Opus, anyone who hits this problem can't switch the bl**dy thing off!
This raises yet another problem with the Opus specification: With all other formats, if some files have ReplayGain information, and some files don't, you can set a separate pre-amp for the non-ReplayGained files to avoid being blasted out by them. Players can do this because they can see which files have ReplayGain tags, and which files do not. This is really useful, because it saves having to ReplayGain scan every podcast and test track that comes through your player - your player can just turn them down by, say, 8dB automatically. However, with this Opus problem where Output Gain might be a ReplayGain value, or it might not be, you've killed this useful functionality as well.
I think we've now got five scenarios where the Opus implementation goes wrong.
Clipping is what sucks most, and that's all you're left with in the Opus implementation. A slightly lower volume or a compressor are both preferable to clipping.
During this discussion, I think maybe you have in mind clipping in typical pop tracks, especially clipping caused by inter-sample overs or lossy compression. In the default Opus scenario (-23LUFs reference Output Gain), that's not what we're talking about at all. We're talking about really wide dynamic range classical pieces getting the peaks of the crescendos cut right off. Some compression, or a lowered level, is vastly preferable in this case.
Do you mean inter-sample overs? That's almost a red herring in this scenario. The kind of mastering that suffers most from inter-sample overs is going to be peaking at about -15dB FS when loudness normalised to -23LUFs. Even so, you can store the peak in accordance with EBU R128 inter-sample over calculations if you want.
Suggesting a way that fixes the problems I've identified is non-constructive? Storing a peak value in a system that's already running an EBU R128 loudness calculation is "adding complexity"?! That's like saying we should stop writing full stops at the end of sentences to save ink.
That would be grand if it worked, but there are just so many ways in which it doesn't.
David.
I think you've summarised the worst problem perfectly.
There are workarounds (you could always install fb2k just to see what it's doing  ), but they are easily broken.
David.
Well I'm fairly settled on what to do about the "worst" Opus gain issue.  I simply give the user an option to decide whether the output gain is an album gain or not.  There just isn't any information I can use to make that decision inside the code, and the consequences of not making it aren't acceptable in the context of a quality music player.
I'm still slightly struggling with the peak scaling issues.  I'm working within a player that treats lack of any peak information as if the peaks are exactly 1 (full scale).  So, assuming that scaling is chosen, all positive gains are essentially ignored.  If there are REPLAYGAIN* tags and peaks, and if I'm using them in preference to Opus gain settings, then all is straightforward just as with any other codec.
However when using Opus gains, I can't realistically use any REPLAYGAIN* peaks so the assumption is that the peak is at full scale.  Much of the time this isn't a problem, because Opus gain values tend to be negative, but using a preamp gain (or the automatic reference loudness correction option) to correct for the inherent quietness of Opus gains means it is easy to end up looking like a track will clip.  I guess that's just tough, and people shouldn't use that setting (to scale back from peak clipping) if they want to boost the gain when they don't have any peak information (or even if they do have peak information!).  It also isn't immediately obvious whether an implicit full scale peak should be assumed with or without the Opus output gain.
Fingers crossed I've handled the other four Opus gain issues adequately.  I've lost track of what they all were
Meanwhile, there is still no opusgain tool
No but I recenty re-encoded my entire collection to opus (I have archival flac) and I did some experiments.
With the reference encoder in Linux anyway, if the flac source has an album gain that gain will be aplied before encoding. So there is no need for an album gain, only track gain, if you follow what appears to be their model.
What I assume to be the difference between album gain and track gain is then written as R128Gain.
If the flac file has no replay information, opusenc does nothing. But if you have the replaygain tags in the source flac, they are applied so that you don't need a separate album gain.
When listening in album mode, no gain needs to be applied.
When listening in random mode, then the track gain is there (though R128 not ReplayGain)
So it appears their model is apply the gain before encode, and then only use a gain value if the track gain differs from album gain.
I actually like that model because it does not depend upon clients to add the gain for it to be a reasonable relative volume to other media in the library.
So I am not sure a separate tool is really needed unless you reject their model and don't calculate the gain before encoding to feed to the encoder.
OT: Is it just me or is the opus encoder much faster than vorbis encoder?
EDIT - after reading another thread, I guess what it actually is doing is putting the album gain in that hidden playback header and not applying it the decoded flac. Same end result I guess.
Reply #32
Correct, the R128 track gain is the difference between the track gain and the album gain (aka Opus header output gain).  You would apply both to get the correct track gain adjustment.  Do you know if opusenc bumps the Flac replay gain values down by 5dB or just copies them across as is?    My version of opus-tools doesn't transcode direct from Flac.  To follow the spec, audio plus Opus gains should be quieter than audio plus Flac (REPLAYGAIN*) gains.
The big gotcha is of course that now you can't turn off replay gain on your Opus tracks.  They will always play with at least the album gain applied.  Hence my endless questions
Although the Opus header gain is not stored in a tag, it is stored separately from the audio.  So the audio is still encoded unchanged and the gains applied after (or during) decoding.  It is even possible to tell the library not to apply either of the gains (even the "mandatory" output gain) and just play the audio as it was originally.
The Opus encoder is pretty fast considering, but it varies a great deal depending on the settings it is used with.  Same for Vorbis.
Okay I feel silly, I've been encoding Opus at 64 kbps because I am toying with starting an icecast server so I wanted to test out 64kbps - but when I encoded vorbis I usually use quality of 6 or 7.
Yeah, that explains it.
Reply #35
Thanks for posting that link. It's a good step in the right direction.
David.
Reply #36
Yes, I think the new tag allows a sensible implementation of gain for Opus tracks.  It leaves more questions than I expected about exactly how much of the output gain, if any, is replay gain and what to do about the rest, but it is possible to come up with a workable implementation without bothering the user with endless questions.
Re: Opus and replay gain
Reply #37
Ugh, i'm still confused about the format of these tags.
According to the RFC, its a Q7.8 value in DB similar to ReplayGain (as Garf stated, ReplayGain - 5). Except then they say (in the next paragraph) that its a maximum 6 character, 16-bit integer with no "dB" in it (i'm assuming its a scalefactor not in dB at all). Which the hell is it??
https://tools.ietf.org/html/rfc7845#section-5.2
Reply #38
Its a Q7.8 value in dB :)  Which is 16 bits (signed), hence an integer in the range -32768 to 32767.  The dB is assumed and not present in the encoding, only the number.  The integer can be converted back to dB by dividing by 256 (ie. shifting by 8 bits).
Reply #39
I realize this is an old post, but I feel compelled to respond to this quote:
The design rationale of the Opus design was clearly to make at least album gain just work even if the player developer had never heard of ReplayGain. This completely dwarfs your (1), (2) and (3) which are all based on the assumptions (s)he knows exactly how it's supposed to work, and even has the UI available to let the user make sane choices based on it. In the case of hardware players, that's obviously not true - how many do you know with full ReplayGain configuration?
Conversely, in the current specification, it will just work. If your player knows about ReplayGain, you get track gain too.
Have you seen how Opus is decoded on Android?  It doesn't "just work" at all.
https://github.com/vanilla-music/vanilla/issues/952#issuecomment-528642366
https://github.com/google/ExoPlayer/issues/7046#issuecomment-605081648
Not gain, but more header problems:
https://github.com/google/ExoPlayer/issues/8396#issuecomment-760213244
Reply #40
Those appear to be issues with players that do their own decoding.
Reply #41
ExoPlayer is a library/dependency, not a player, that Google pushes developers to use rather than the decoder inside the Android OS.
My point remains that even today, it is far more difficult to get loudness normalization to work correctly with Opus files than it is to get it to work with other common music file formats like mp3/m4a/ogg/flac on Android.
Reply #42
Must say I am totally confused about Opus and loudness metadata. What I got out if it is this:
- Opus doesn't store Replaygain (track/album) peak values because standard forbids, for whatever good reasons
- Trackgain/Albumgain values can be saved
- There is also a Opus header gain value stored. ?!
- Foobar has a dedicated screen, "Manipulate Opus header gain" - Apply = Re-Encode? Just write a header? Or apply without re-encoding (as mp3directcut did). I guess the latter.
- That screen has "Lower adjustments according to peak levels" - But opus files hold no peak level metadata?! Or rather values it calculates on-the-fly?
Rocket science for mere mortals I think.
Reply #43
Incorrect - the standard doesn't forbid, it merely advises against the usage of ReplayGain tags:
   To avoid confusion with multiple normalization schemes, an Opus
   comment header SHOULD NOT contain any of the REPLAYGAIN_TRACK_GAIN,
   REPLAYGAIN_TRACK_PEAK, REPLAYGAIN_ALBUM_GAIN, or
   REPLAYGAIN_ALBUM_PEAK tags, unless they are only to be used in some
   context where there is guaranteed to be no such confusion.
   [EBU-R128] normalization is preferred to the earlier REPLAYGAIN
   schemes because of its clear definition and adoption by industry.
   Peak normalizations are difficult to calculate reliably for lossy
   codecs because of variation in excursion heights due to decoder
   differences.  In the authors' investigations, they were not applied
   consistently or broadly enough to merit inclusion here.
Note, specifically, that the standard states "SHOULD NOT", not "MUST NOT".
Yes, Foobar uses the header gain for album gain purposes instead of the R128_ALBUM_GAIN comment tag (which is why I stopped using it). I tried explaining to the devs that this is not how the header gain value should be used, but they didn't care. 🤷
Reply #44
We have been here from the beginning of Opus. In the discussions on the forum and IRC it was clear the authors don't want peaks included. So it should be respected.
The specs you quoted tells the reason "A muxer SHOULD place the gain it wants other tools to use by default into the 'output gain' field, and not the comment tag."
But foobar2000 has supported the R128_ALBUM_GAIN after it was added to the specs. And there is configuration option to even override the spec recommendation and force use of the tag over header value.
Could you please educate what the problem is?
Reply #45
That doesn't contradict literally anything I've said. From the standard itself it is clear that the authors "don't want peaks included", whence the use of "SHOULD NOT". But the fact of the matter is that the standard doesn't forbid the inclusion of peak values, it only discourages it.
I haven't said anything incorrect and you haven't disagreed with me, yet you phrased what you said in a manner that indicates disagreement. Kinda confusing.
Sure!
First of all, a specific loudness normalisation gain should not be something the muxer "wants other tools to use by default". Whether track- or album-based or even no (this one is important - see next paragraph) loudness normalisation should be used should be up to the decoder's/player's settings.
Furthermore, "use by default" out of context is misleading here, because it indirectly implies that the "other tools" can opt to not apply the header output gain. Whether that is true or not remains in a bit of a logical limbo, because the standard states:
       Players and media frameworks SHOULD apply it by default.  If a
       player chooses to apply any volume adjustment or gain
       modification, such as the R128_TRACK_GAIN (see Section 5.2), the
       adjustment MUST be applied in addition to this output gain in
       order to achieve playback at the normalized volume.
The very first sentence makes it seem like a player can indeed decide not to apply the header output gain ("SHOULD").
However, the very next sentence means that any player that does any volume control whatsoever (i.e., any player) can not decide not to apply the header output gain ("MUST").
In my experience, even a command-line tool like opusdec which actually does not do any volume control can not opt to not apply the header output gain.
Ergo, the header output gain is not "used by default", but is just used and there's nothing a user can do about it.
In other words, this
is only correct insofar as forcing any player to apply the album gain aligns with the spec recommendation, which is really not specified anywhere in the spec and is purely a developer judgment call.
Reply #46
foobar2000 for example allows users to decide whether to use this info or not. It's tied to ReplayGain control.
The original specs made it clear that the header gain value is meant to be used for album gain: https://wiki.xiph.org/OggOpus#Comment_Header.
There is no comment field corresponding to Replaygain's ALBUM_GAIN; that information should instead be stored in the OpusHead 'output gain' field.
But as was mentioned, foobar2000 has had configuration for this since 2016. By default it retains the old behavior that Opus was born with and uses header gain field for album gain. But you can configure header to remain as null and then gain gets only stored in the two R128 gain tags.
I think your problem with foobar2000 is based on some huge misunderstanding. It fully follows the specs and allows user full control of the gain behavior. Both for encoding and decoding.
Reply #47
Well it shouldn't, because that is literally against the spec.
Foobar2000 has volume control, and - once again - straight from the spec:
       If a player chooses to apply any volume adjustment or gain
       modification, (such as the R128_TRACK_GAIN (see Section 5.2),) the
By being able to have volume control and not apply the header output gain, foobar2000 is literally breaking the spec.
The original specs
are outdated and irrelevant. The OPUS spec is here.
On the contrary, my problem with foobar2000 is based on proper understanding.
It actually literally does not, as I've clearly explained at the top of this post.
Reply #48
Honestly, this is my problem with foobar2000. I can literally copy-paste straight from the OPUS spec the part of the spec that foobar2000 is breaking, and - somehow - a literal copy-paste from the spec gets ignored and dismissed as "some huge misunderstanding", and foobar2000 gets proclaimed to "fully follow the specs".
I mean, if you just don't want to make it work by the specs, just say that. But this thing you're doing where you pretend that your disagreement with what I said isn't also in disagreement with the actual spec itself is honestly getting ridiculous and annoying.
Reply #49
Maybe language lawyering over which RFC2119 definition "forbids" corresponds to exactly wasn't the best way to get to a constructive discussion.
You're assuming here the decoder or player HAS these settings or even knows what ReplayGain is. When we discussed this 8 years ago there was no such assumption that all players would have this, and I suspect that's largely been borne out in practice too. So if, as a user, you want Album ReplayGain, then that's what you want your muxer (in this case foobar2000) to write out in the gain field, because that's the very minimal one the player will apply. (The discussion a few posts above points out that even that is gotten wrong by some libraries, but of course at that point all bets are off...)
If you want Track Gain instead, your muxer needs to be configurable to write that out to the gain field instead.
The foobar2000 behavior that you seem to object to is the one that gives the most desirable behavior with the dumbest players (while still working with better ones). If you have a problem with that, that's on you, but don't be surprised that the developers continue to ignore you.
Going back through the past comments and how the spec evolved, you can actually see that R128_ALBUM_GAIN didn't exist initially, and was a reason for 2BDecided's frustration with not being able to interpret the default gain value. So arguing that the default gain shouldn't be album gain and that this is somehow wrong is weird, because it would mean that'd have been a backwards incompatible change and the format would've been Opus 2.0 (no such thing happened!). I'd still maintain that a player that writes out R128_ALBUM_GAIN with non-zero values and a neutral internal gain field is just being bad, because it will break loudness equalization in non-ReplayGain capable playback devices, for *no advantage whatsoever* in players that do actually support it.
It doesn't imply any such thing. It describes what will happen if the user doesn't configure anything, or CANNOT configure anything, because the player doesn't really know about ReplayGain.
We can now language lawyer a bit more whether the final output volume being different from what's in that tag (due to the user selecting another ReplayGain mode or there being additional album gain tags causing an additional scaling) means that the stated gain is "being applied" or not, but the spec makes it clear (and was always clear) that all the other gains are on top of that one, so there's no real misunderstanding possible in the implementation.
Arguing that a player having *an option* to ignore parts of the spec is "breaking the spec" is simply not interesting.
