Topic: foo_mirc no worky (Read 4074 times) previous topic - next topic
foo_mirc no worky
I can't seem to get foo_mirc working. There is no alias sent to mirc. Anyone else get this working?
foo_mirc no worky
same to me. Using mIRC with NoName Script.
foo_mirc no worky
I use it with NoNameScript too and it works perfectly.
/foobar and mirc should recognize it. at least it did for me.
foo_mirc no worky
Well, i had it working with /foobar too :/
only problem is now i had to reinstall my os because it died :\ and now the link to the mirc plugin is gone... i know aimp exists, but its very slow when it updates mirc, the foo_mirc was way better for that :/
can anybody tell me where to find it again? (the link on the general plugin page is dead)
foo_mirc no worky
Yeah, I'm looking for the foo_mirc.dll for ver 6 too.
I dont like AMIP either, tends to either crash or seriously slow down Foobar which is why I have rolled back to ver 5, where my mirc plugin is still compatible.
If somebody could send me the version 6 plugin, I'd be most grateful.
foo_mirc no worky
I've rigged up r1ch's winamp/foobar compatibilty crap to make this:
foobar/winamp/dll/thingy
basically its a modified sysreset winamp script, combined with the r1dll winamp compatibility layer used with foobar..  toss the foo* into the foobar directory, and the r1dll into your sysreset directory. then toss the r1dll_addon.ini into your sysrest addon/ directory, then you can load it via the addon manager like the normal winamp plugin.
please note, i didn't bother doing a pile of stuff with it, so its still called the winamp scanner etc... i just did enough to get it scanning foobar instead of winamp..
on the plus side, if you have winamp running instead of foobar, the scanner will still work . the r1dll is pretty sweet that way =D
ill probably leave that link up for a month or so... dont wanna abuse my bandwith too much..
