Topic: Playback queue flushes after playing from ML search (Read 1875 times) previous topic - next topic
Well, maybe someone will tell me that it isn't a bug but it is strange to me and I haven't noticed it before...
Today I noticed, that if I build playback queue and then at some moment I will open Media Library Search window and play something from results, my queue is flushed... Why this happens? Can I do something to change it and keep queue in such scenario? I use foobar 1.2.9. I use foo_keep_queue plugin and it works when I close foobar, but it seems it is unrelated to interruption of playback when ML serach is invoked... Everything is fine when I use simple playlist search. In this case queue is not flushed and it continues play after track from results finishes. I expected the same with ML Search.
Anyone?
Have you tried disabling library viewer selection playlist in the media library sub menu in the foobar2000 preferences?
Doesn't help...
Maybe I should ask additional question - does anyone notice the same behavior?
Queue flushing upon manual track selection is an intended feature. The component foo_keep_queue is bugged and fails to save queue contents when playing tracks from the library search.
Thanks for reply Case
How I understand your post, taking my quite long time foobar experience into account:
1. Queue flushing upon manual track selection is an intended feature of foobar's core. This is how Peter/other main dev has decided that it should be. It happens in any scenario - F3 search, ML search, simple doubleclicking somewhere on playlist.
2. foo_keep_queue was intended to change behavior from point 1. in every possible scenario, but it has a slight bug, and scenario with ML search is not supported. From the point of foo_keep_queue this is not intended to flush queue when ML search is invoked - this is only because of bug.
Am I correct? Bit pity that foo_keep_queue developer seems to be long time inactive...
