Topic: foo_youtube (Read 514272 times) previous topic - next topic
Re: foo_youtube
Reply #725
the results list can only be emptied manually and only after opening Youtube search window (i.e. it won't reset even after foobar restart), which results in permanent focus on results list after the first search (unless your search returned no results).
Note about empty list was for completeness. Main point of current behavior is to restore focus where it was last time. If last time the focus was in search box, initial focus will also be there. If it was in the list, then initial focus will be in the list and on the same list item as before.
Any solution is better than none =)
Will be in next beta.
Re: foo_youtube
Reply #726
Can someone help me to find the reason why thumbnails do not appear in the appropriate folder?
In the following the elements to describe the context:
  • stock portable installation on XP sp3
  • foo_youtube_1.18_preconf_xp
  • album art enabled in preferences
  • nothing appears in \3dydfy\thumbnails but the log says "Downloading thumbnail, successfully downloaded"
  • the same installation, if run on a windows 10 host, downloads thumbnails correctly
  • using an external libcurl does not change the result (see log)
21:22:56, (ext) libcurl/7.44.0 OpenSSL/1.0.2d zlib/1.2.8
21:22:56, Video: LAV Splitter 0.69.0 (int), LAV Video 0.59.1 (int), VSFilter 3.0.0 (int)
21:22:56, ffmpeg (int): lavf 57.56.100, lavc 57.64.101, lavu 55.34.100
21:23:00, #01, Page analysis, youtube.com/watch?v=CoBT59xRElU
21:23:00, #01,     Opening given Youtube URL...
21:23:12, #01,     Getting info about clip, processed 0 of 22 clip(s)...
21:23:12, #01,     01/22: MP4 240p 426×240 30fps 10.16 MB VO
21:23:12, #01,     02/22: MP4 360p 640×360 30fps 2.53 MB VO
21:23:12, #01,     03/22: MP4 480p 854×480 30fps 4.67 MB VO
21:23:12, #01,     04/22: MP4 720p 1280×720 30fps 9.17 MB VO
21:23:12, #01,     05/22: MP4 1080p 1920×1080 30fps 21.39 MB VO
21:23:12, #01,     06/22: M4A 44100Hz Stereo 127kbps AO 5.26 MB
21:23:12, #01,     07/22: MP4 144p 256×144 15fps 4.62 MB VO
21:23:12, #01,     08/22: 3GP 144p 176×144 10fps 1.47 MB
21:23:12, #01,     09/22: OGG 44100Hz Stereo 119kbps AO 4.91 MB
21:23:12, #01,     10/22: MP4 360p 640×360 30fps 10.40 MB
21:23:12, #01,     11/22: MP4 720p 1280×720 30fps
21:23:12, #01,     12/22: WebM 240p 426×240 30fps 1.06 MB VO
21:23:12, #01,     13/22: WebM 360p 640×360 30fps 1.66 MB VO
21:23:12, #01,     14/22: WebM 480p 854×480 30fps 2.40 MB VO
21:23:12, #01,     15/22: WebM 720p 1280×720 30fps 4.39 MB VO
21:23:12, #01,     16/22: WebM 1080p 1920×1080 30fps 13.81 MB VO
21:23:12, #01,     17/22: OPUS 48000Hz Stereo 52kbps AO 2.17 MB
21:23:12, #01,     18/22: OPUS 48000Hz Stereo 71kbps AO 2.94 MB
21:23:12, #01,     19/22: OPUS 48000Hz Stereo 137kbps AO 5.68 MB
21:23:12, #01,     20/22: WebM 144p 256×144 15fps 1.14 MB VO
21:23:12, #01,     21/22: 3GP 240p 320×180 30fps 5.09 MB
21:23:12, #01,     22/22: WebM 360p 640×360 30fps 8.87 MB
21:23:12, #01,     Total time consumed: 11.907 seconds
21:23:12, #01,     Ready
21:23:12, Audio opening opus (https): download - foo_youtube, decode - ffmpeg
21:23:12, Activity#1 (audio.play): OPUS 48000Hz Stereo 137kbps AO | 5.68 MB
21:23:12, Audio opening finished in 0.461 seconds
21:23:14, #02, Downloading thumbnail
21:23:15, #02,     Downloading thumbnail, successfully downloaded
21:23:15, #02,     Total time consumed: 0.821 seconds
21:23:15, #02,     Ready
Re: foo_youtube
Reply #727
Fixed in current beta. Thanks for report.
Re: foo_youtube
Reply #729
hi 3dyd
great plugin, respect from russia
when i try add playlist File->Add Location https://www.youtube.com/playlist?list=PL0551E080B5AD93EA
appears popup window Information: The following error(s) occurred during loading of the location(s):
Security error
reason?
windows xp sp2, foobar v1.3.14, foo_youtube_1.18.1_beta3_preconf_xp
Re: foo_youtube
Reply #730
How do I manually open the video?
Re: foo_youtube
Reply #731
@gr8cx
foobar2000 does its own check of HTTP(S) URLs before they go to the component. Google uses SHA-256 certificates at minimum, and XP SP2 does not support SHA-256. So that check fails and component does not get these URLs.
AFAIK there are no way to pass that check. But it can be avoided. To do that, go to 'Preferences -> Advanced -> Networking' and add www.youtube.com in Suppress HTTPS certificate checks for domains.
@Skreaxy
Maybe 'View -> Visualizations -> Youtube Video' is what you need.
Re: foo_youtube
Reply #733
I confirm that now thumbnails are working. My 15yr old laptop says thanks...
If you create a playlist from youtube search and let it play, the first thumb is shown correctly, but the following do not show.
It seems that thumbs are shown only following a user event (e.g. play, skip) and not when a track starts following the end of another.
Re: foo_youtube
Reply #734
Component does not decide for which item an album art is currently displayed. I suppose you need to turn on 'Cursor follows playback' in menu Playback to get behavior that you are expecting.
Re: foo_youtube
Reply #735
I get this error:
     Unable to open item for playback (Youtube Source: Page analysis, Couldn't resolve host name (6)):
"youtube.com/watch?v=1VUa99-tJqs"
I have noticed that this error occurs when its a music video or a song but when it's a video it doesnt appear this error
Also I selected to open the video in manually but not in fullscreen but it opens in fullscreen in the thumbnail not in the View - Visualizations - Youtube Video
Re: foo_youtube
Reply #736
Yes. Some clips started giving it. Should be fixed in current beta4.
Re: foo_youtube
Reply #737
Also I selected to open the video in manually but not in fullscreen but it opens in fullscreen in the thumbnail not in the View - Visualizations - Youtube Video what is the cause of it?
Re: foo_youtube
Reply #738
To clarify. in component preferences -> Video tab -> 'Show video frame' combo box you have 'Manually' (not 'Manually (fullscreen)'. And when you go to menu View -> Visualizations -> Youtube Video, it appears fullscreen? Are you sure it is in fullscreen? There could be just a big frame window, if you select video resolution near to your screen resolution.
Re: foo_youtube
Reply #739
New version 1.18.1
Changelog:
- search position to %tracknumber%. Optional feature under additional Extensions group of search config menu (either integrated search or popup window). If enabled, track position in search results will be stored in %tracknumber% meta
- option Fit to video in video UIE. Will resize video frame within UIE to retain the same aspect ratio as source video. I.e. no black areas around video in UIE, that area will be filled by panel background (or will be transparent if this is enabled in CUIE)
- video UIE got same set of panel options (panel border, transparent background in CUI etc.). Reminder: in DUI panel options are available in panel context menu only when layout editing mode is enabled
- initial focus to search box. Option in Search popup window to always set initial focus to search box when the window appears on the screen. Available under Extensions group of search config menu. It is unchecked by default, what means to retain focus on the control which had it last time the window was visible
- appearance fixes for high DPI. Size and position of popup windows will be reset as side effect of these fixes
- fixed inability to display thumbnails as album art on XP
- fixed inability to add feeds using menu 'File » Add multiple URLs...'
- fixes for transparent background in CUI: correct redraw at panel resize / move, correct redraw of panel border, fixed drawing artifacts in Activity and Log
- fix for Youtube (some clips started giving an error "could not resolve host name")
Re: foo_youtube
Reply #740
I have the Option selected in Manually and the menu View -> Visualizations -> Youtube Video works fine. I got a new Tabb in a Layout and I added there the Youtube Video and when i double click there it opens in fullscreen, isn't supposed to open in the resolution that it's defined?
Re: foo_youtube
Reply #742
It does not work like that. Video UI element can be either part of UI (as you have it within Tab) or full screen. Video popup window (Visualizations -> Youtube Video) can be either a popup window or full screen. There are no transition between popup window and UI element. Resolution settings are for choosing source video to play, not for destination window where it will be played.
Re: foo_youtube
Reply #743
I have recommendation, is it possible to add ''auto update'' option, so user can select that , and when new update is available , foobar will update component automaticaly with message ''youtube component was updated, restart now?'' , and option to revert to previous version if something not work? .. So we don't need to doing this manualy? I think this is possible..
Thanks..
Re: foo_youtube
Reply #744
Although this looks to be possible, this is teetering on the edge of SDK restrictions. Or most likely is beyond that edge.
Re: foo_youtube
Reply #745
hi 3dyd
i have problem last three days
view->search ANY KEYWORD then play
Unable to open item for playback (Youtube Source: SSL connect error (35)):
"youtube.com/watch?v=IwpDzJE4fc8"
"youtube.com/watch?v=gACAQaYpI7U"
"youtube.com/watch?v=84kbG2ExdZs"
Re: foo_youtube
Reply #746
Yes, it looks like they have switched to more secure HTTPS that is not supported by Windows XP native backend. Even XP SP3 does not work. Though I didn't dig much into the problem since alternative SSL backend solves it.
So, get alternative SSL backend from download page and select it in component preferences -> Maintenance -> External Binaries -> libcurl.
Re: foo_youtube
Reply #747
helped thanks, it work
Re: foo_youtube
Reply #748
Strange error does not know if plugin or Youtube - type a in the Foo_youtube search phrase: Deep Purple Abandon and any suggestions or results - while Google find easily and Youtube too.
Re: foo_youtube
Reply #749
So neither search itself nor search autocomplete don't work for you?
