Topic: foo_youtube (Read 234445 times) previous topic - next topic
Re: foo_youtube
Reply #1225
Thank you. I'll check.
Re: foo_youtube
Reply #1226
"To continue with your YouTube experience, please fill out the form below"
There was no such message..
Fallback Text
It may be useful, but I do not have time to read it (when switching 480p).
Сan You make a delay that would be text-displayed yet a few seconds(or call it with one touch) after the video?
Re: foo_youtube
Reply #1227
Article you've quoted describes how to deal with HTTP 429 error. So either your issue is not HTTP 429 or you've not used browser's Incognito/Private mode or they've changed something so these instructions are not relevant anymore. In the latter case I won't be able to advise unless I reproduce it.
No, but you can remove fallback text in component preferences Video ->Window -> Fallback Text -> Pattern.
Re: foo_youtube
Reply #1228
Hello Folks, anyone knows about how to listen to / play Radio Garden audio web-streaming?
Regards, Andrea
Re: foo_youtube
Reply #1229
Any way to bypass this YouTube age restriction thing or whatever it is?
Foobar You-Tube plugin pop-up info:
Unable to open item for playback (Youtube Source: This video may be inappropriate for some users. | Analysis, no video found on Youtube URL): "youtube.com/watch?v=TN9FsOSWy8w"
Example song: www.youtube.com/watch?v=TN9FsOSWy8w
Re: foo_youtube
Reply #1230
There is no way to do this with this component unless youtube-dl adds Radio Garden support.
All I can say on the topic is collected in this article: Authenticated access on Youtube.
Re: foo_youtube
Reply #1231
Well went to the URL, followed instructions, but I cant seem to find the thing you give instructions to do.
Went to URL, F12, Refresh, Copy cURL.
But then the instruction on where to paste it is a bit unclear for me.
Quote:  Component preferences Network HTTP Enable persistent cookie storage Storage Modify Paste OK OK.
But in FooBar I can not find that in FooBar.
http://prntscr.com/riyfyl
And I could not see any components that matched either, and I did not find any info in the instructions that any component was needed.
http://prntscr.com/riyhnt
So if Im missing something plz let me know, either writing here or updating the instructions.
Re: foo_youtube
Reply #1232
It is about preferences of the component (of foo_youtube component since the site is for foo_youtube). I.e. Preferences -> Tools -> Youtube Source -> Network tab.
Re: foo_youtube
Reply #1233
Oki, that explains why I dint find the settings, found it, worked fine, awesome.
Re: foo_youtube
Reply #1234
How to remove blinking when changing the built-in chapters?
Trying to watch Contagion (1080p HD) .m4v.
It really bothers ..
Re: foo_youtube
Reply #1236
I can’t create a button on the panel, I try to make it from the context menu, it is absent, the specified parameter is the artist - track
Re: foo_youtube
Reply #1237
Stumble upon yet another video that is not working.
And I did do " All I can say on the topic is collected in this article: Authenticated access on Youtube. " and it worked. But this is still blocked somehow.
Unable to open item for playback (Youtube Source: foo_youtube: server error (403) from r2---sn-uxaxovg-5gor.googlevideo.com | ffmpeg: Server returned 403 Forbidden (access denied) | foobar2000: Access denied):
"www.youtube.com/watch?v=HIWY8UyW9bw"
https://www.youtube.com/watch?v=HIWY8UyW9bw
Re: foo_youtube
Reply #1239
Yes, and it should be fixed in 3.6.
Video playback is independent logic on top of the audio playback. It just pretends to be working together with the audio. Avoiding blinking in described use case is hardly possible. You may consider using video player for watching movies.
Re: foo_youtube
Reply #1240
:-\  ..OK
