Topic: New Public Multiformat Listening Test (Jan 2014) (Read 88638 times) previous topic - next topic
Reply #200
Enable AAC_HE profile with VBR 2
Enable AAC_HE_V2 profile with VBR 1
With ffmpeg, you can do this with -profile:a aac_he{,v2}. Or you can use the -t parameter in aac-enc.
It looks like without explicitly setting the profile all vbr modes produce AAC-LC streams. I encoded only two albums (Shpongle and Prodigy) with "-m 1" and got 94.1kbit/s and 95.1kbit/s (AAC-LC) respectively with cut off at 13.1kHz.
keeping audio clear together - soundexpert.org
Reply #201
lvqcl, dakbyte, gainless,
Which FhG encoder(s) do You prefer to see in test?
Reply #202
So it's acceptable for AAC, but not for Musepack? I realize that interest in Muepack is low, and that it likely will not perform that well. But at least arguments should be consistent.
1) I didn't say that 14 kHz is good for AAC encoding  For me, it's also too low.
2) From FFmpeg and AAC Encoding Guide: "But beware, it defaults to a low-pass filter of around 14kHz. If you want to preserve higher frequencies, use -cutoff 18000. Adjust the number to the upper frequency limit you prefer."
So, this guide recommends to tune the encoder and not to use default lowpass value.
FDKAAC has some drawbacks: experimental VBR mode, too low lowpass... I prefer FhG encoder as in Winamp.
Reply #203
Just make "wide open" test with fullband FAAC (120-125 kbps) and results will astonish you. That's is 10 year old anchor. I hesitate what from it someone away off will come off.
Reply #204
I'd rather like to hear comment on libFDK VBR mode from Chris.
Reply #205
For FhG I prefer the Winamp version, for the test the more popular and better rated Apple encoder seems more sensible though. As there shall be only 4 codecs included, my vote is now:
Opus (1.1)
Vorbis (AoTuV)
Apple AAC
FAAC at 96 kb/s as low anchor
96 kb/s as overall bitrate.
Reply #206
Gainless,
It's 4 codecs + low anchor (s).
Reply #207
Gainless,
Nevermind then
Opus (1.1)
Vorbis (AoTuV)
Apple AAC (CVBR)
+ Helix Mp3, 128 kb/s
FAAC at 96 kb/s (low anchor)
Reply #208
Although my music is predominantly lossless, I just listened 2x 2hours to 20 of my favorite songs, which I encoded with Opus 1.1 to 80 and 96kbps. Eventhough it was just casual listening, there actually wasn't a moment I could tell I was listening to lossy music! I was thus really surprised by the transparency of 80kbps. This leads my to believe that testing 96kbps is overkill and will be very hard!
My votes therefor go to:
Opus 1.1 - 80kbps (--bitrate 80)
Aac (Apple) - 80kbps*
Vorbis (aoTuVb6.03) - 80kbps (-q1)
Mp3 (Lame 3.99.5) - 80kbps (-b 80)
*I never encode to aac, so I know nothing about settings and which version is better, but as the title of this thread is "Multiformat Listening Test" it would only be logical to put forward 1 aac contestant.
I agree. Had a great deal of difficulty with the last 96kbps test using good equipment with old ears though.
Reply #209
For my vote I would like to finally, if possible, end the debate of CVBR vs TVBR in AAC, preferrably Apple's encoder. The last test showed only a tendency for CVBR to be rated higher with no clear winner.
Maybe the bitrate should be pushed lower to do this.
It will be hard to answer this question.  According to this  personal test CVBR is on par with TVBR
Reply #210
I prefer the FhG Winamp encoder. It's good to have a "higher quality than FAAC" open source encoder (FDK) but at 96kbps VBR it uses a too low lowpass cutoff which is very noticable for me. The Winamp encoder is obviously better with this.
I wonder if we could include Opus @80kbps and Opus @96kbps in the test aswell?  I think testing AAC-LC @80kbps doesn't make much sense, but it would be really interesting if Opus @80kbps could beat AAC-LC encoders @96kbps or not. Maybe Apple HE-AAC CVBR @80kbps or FhG VBR 2 for the same reason?
WavPack -b4x4hc
Opus --cvbr --bitrate 256 --framesize 5
Reply #211
Opus' outcome will be very interesting of course, but I can't see why expectations for Opus are that high. When I did some listening @96kbps a few days ago Opus and AAC performed great, with regular music as well as problem samples, with one exception: harp40_1 was encoded pretty badly, but only by Opus.
lame3995o -Q1.7
opus --bitrate 140
Reply #212
I think a discussions of possible results generally leads to premature prejudice. That doesn't help.  Let's not discuss  quality of competitors. We will see later.
After the end of test  everybody will be welcome to give their opinions and observations.
Reply #213
Bitrate distribution of the major encoders:
Reply #214
It's still not clear whether Opus@96k is any good comparing to AAC@96.
And now it's evident there is a need in a new AAC test. But it should be organized separately from this one as it's too much work to do.
Until now the list of the most voted codecs:
1. Apple AAC  - 22 votes
2. Opus - 22
3.  Vorbis - 11
4. MP3@128k - 9
(?)+ low anchor - FAAC 96 kbps CBR or ABR
Also I think it will be useful to include a low-middle anchor in addition to a low anchor. Thread..
Shortly, a quality of recollected results should be higher because now a listeners should rank low-middle anchor higher than low anchor. If some particular listener rank the low anchor higher than  it's an indicator that something is wrong.
MP3@96 kbps has received a high number of votes , 8.
Two birds in one shot! MP3@96kbps as low-middle anchor + we test it as one additional codec at 96 kbps.  Fortunately it's actually easy to test MP3@96 kbps. So it can be a good idea to add this codec despite we have already high enough number of codecs.
What do You think?
Reply #215
What about LAME 3.99.5 -V 4.99 (lvqcl's  post) or halb27's 3.100m?
It's rather non-MP3@96 (real bitrate ~100 kbps) vs MP3@128 (real bitrate ~135 kbps)
Edit: fixed link
Reply #216
So if mp3@128kbps is to participate I'd welcome 3.100alpha2 because of its improved behavior for tonal issue (listen to Angels_Fall_First for instance).
Sure because of improved short block behavior I prefer my lame3100m variant over the original.
lame3995o -Q1.7
opus --bitrate 140
Reply #217
Reply #218
Yes, we know that. But what about an average people saying that it was alpha and not final?
Reply #219
I understand that.
We should just collect votes, and I gave mine. To be precise: I vote for lame3100m -V5.
lame3995o -Q1.7
opus --bitrate 140
Reply #220
mp3 encoders, including the lame 3.100.a2 64bit and the ultra-fast Helix.
Reply #221
Sure.
Aslo it will be interesting to hear what Robert will tell.
Reply #222
Updated.
Guys, check if your codec choice was submitted appropriately.
There is still one day (tommorow) to submit changes.
Reply #223
I bootstrapped the last 2011 public listening test of AAC encoders @ 96kbps (280 donated results, 20 samples) to plan this upcoming test.
The past data may not be precisely applicable to an another future test, but you may get a 'sense' of 'How much effort do we need to bring the error margin down?' or 'Which plan is likely to make better use of the precious donated time?'. Enjoy!
If I interpret this correctly, instead of using 20 samples and a bunch (~14) of listeners, we could've used 65 samples with 2 listeners and have gotten an as accurate result (though way less useful for the developers) with less than half the effort? That's pretty mind-blowing.
Imagine there is 1 listener and infinite number of samples. Will it be as good as 10-15 listeners and 20 samples?
I think the graph implies an ideal correlation between the results of different listeners. Well, it's not totally uncorrelated but it's not 100%.
An ideal correlation would imply that all listeners have exactly the same hardware (headphones ...), exactly the same hearing, exactly the same age. etc.. etc.. etc...  That's why the results of one individual can't be enough representative even on infinite number of samples.
That's why I've mention about an inter-listener correlation a few times.
Reply #224
In case you have missed something. The listener is re-picked from the 25 listeners(2011 AAC@96) in each sample.
So if there is 1 listener and 1000 number of samples, The average workload for each listener is 40 samples.
