Topic: exporting an mp3 mix for mixcloud (Read 1475 times) previous topic - next topic
I'm not into DJ software, but I like making mixes/playlists in FB2k.  I would like to start uploading some mixes to Mixcloud.  Unfortunately all Mixcloud uploads need to be a single file.  Is there a plugin that could assist with this?  It would just need to take an hour or so worth of mp3s and combine them into a single new file.  I'd like to avoid using other software to do this... I know you can do it manually in Audacity, but it's very time consuming.
Suggestions?
Thx in advance.
The converter component has a mode where it will output all input files as a single output file without a cue sheet. That will involve some transcoding, but should be adequate for converting from a set of files of any format. Check the context menu, if you have the converter installed (which comes bundled with the player), Convert -> ... -> Destination -> Merge all tracks into one output file.
