Topic: Opus 1.1 (Read 43149 times) previous topic - next topic
Opus 1.1
Reply #50
Found a way to fix this problem: in function seek_forward (in audio_in.c) comment out fseek():
static int seek_forward(FILE *in, unsigned int length)
    //if(fseek(in, length, SEEK_CUR))
        /* Failed. Do it the hard way. */
        unsigned char buf[1024];
        unsigned int seek_needed = length;
added: currently opusenc uses fseek() to skip over "LIST"  chunk, and this somehow prevents further reading/seeking
Doesn't it look familiar? IIRC, I saw similar code in flac frontend in the past.
fseek() on a non-seekable file is guaranteed to fail on Posix, but not on Windows. Therefore, "try to seek first and read when fail" doesn't work...
Opus 1.1
Reply #51
So another solution is to use #ifdef?
#if !defined _WIN32
#endif
Opus 1.1
Reply #52
#if !defined _WIN32
#endif
I have uploaded a build of opustools with this mod in place. If someone would kindly confirm this works OK, I'll complete other relevant recompiles and upload.
It's available here: http://www.rarewares.org/files/opus/opus-t...win32_SSE-1.zip
TIA.
Opus 1.1
Reply #53
This one works, john33.
ffmpeg.exe -hide_banner -i input.avs -c:a copy -f wav - | qaac.exe --silent -D - -o - | opusenc.exe --bitrate 64 - output.opus
ffmpeg.exe -hide_banner -i input.avs -c:a copy -f wav - | opusenc.exe --bitrate 64 - output.opus
Now both produce the same output. Thank you, lvqcl and john33!
Upon having loaded the AviSynth audiostream ffmpeg does still notify me though with: "[wav @ 02f8d700] Using AVStream.codec.time_base as a timebase hint to the muxer is deprecated. Set AVStream.time_base instead." Does anyone know by chance if this is important/bad?
Btw john33, I see you grabbed opus-tools 0.1.8 for this fix, but 0.1.9 is out already.
Opus 1.1
Reply #54
Thanks for the feedback, and the 'heads up'. I'll sort new compiles out tomorrow.
Opus 1.1
Reply #55
Opus-tools updated on Rarewares to 0.1.9, including the bug fix. I'll get to the oggenc2 compiles later.
Opus 1.1
Reply #56
What's new on this one? Same fix?
Opus 1.1
Reply #57
opusenc.exe -V
opusenc opus-tools  (using libopus 1.1.x-git)
Copyright (C) 2008-2013 Xiph.Org Foundation
Could you please recompile and enter the opus-tools version, because opusinfo.exe, but especially MediaInfo reads those entries.
"libopus 1.1.x-git" means compiled from latest git at that moment I guess?
P.s. http://www.rarewares.org/opus.php --> you seem to forgot a "<" in front of "/span>".
Opus 1.1
Reply #59
opusenc.exe -V
Recompiled, as requested. Sorry, I thought I'd taken care of that! Yes, latest git.
opus.php fixed as well, thanks again!
Opus 1.1
Reply #62
You can steel fskip_ahead() from FLAC frontend:
https://git.xiph.org/?p=flac.git;a=commitdi...6a8645e83be9768
LAME has similar function named fskip() in get_audio.c, in which only S_ISFIFO is treated as a non-seekable candidate.
Completely killing fseek() on win32 is usually fine since what is skipped is usually tiny.
However, AIFF can have COMM(=header) after ssnd(=PCM data), in which case HUGE amount of block has to be skipped by fread() before reading COMM.
Opus 1.1
Reply #63
Code 'stolen' from FLAC fronted!  Could someone kindly check that I've amended this in a way that it performs correctly? TIA.
It's here: http://www.rarewares.org/files/opus/opus-t...win32_SSE-1.zip
Opus 1.1
Reply #65
Piping 32bit float AviSynth audio from ffmpeg to opusenc works for me. Thanks.
Excellent.  Thanks for letting me know. I'll proliferate new compiles that use this code.
Opus 1.1
Reply #66
john33, thanks for the new builds again.
Is SSE2 optimised instead of SSE on Opus 64bit a typo?
Opus 1.1
Reply #67
No, it's not a typo, I just selected the SSE2 compiler option on all the Opus x64 component builds.
Opus 1.1
Reply #69
eahm, all x64 CPUs must support SSE2, so there's no harm....
True.
Even the very first 64-bit Athlons (ClawHammer and Newcastle from september 2003) already had SSE2 support. So there's no 64-bit desktop CPU from Intel or AMD without SSE2.
2 john33: thanks for releasing new opus builds. Btw do you still plan to create opusdropXP one day ?
Opus 1.1
Reply #70
Hi
It's been fixed ---> fixed
Opus 1.1
Reply #72
Why file converted 2 times with same encoder options (--bitrate 128) with last official codec opus-tools 0.1.9 they have different structure/checksum?
Opus 1.1
Reply #73
Timestamp? Unique conversion id?
Opus 1.1
Reply #74
Diagnostic options:
--serial n         Forces a specific stream serial number
