Topic: File size / quality questions and more... (Read 14735 times) previous topic - next topic
So after all the bickering,  the original question stands.
I'll just re-rip the things obviously I asked in the wrong place.
What bickering, people have been giving you solutions.
1. Check that the files are definitely FLAC, easy enough to do whatever the OS.
2. If they're FLAC with minimal compression just reencode as FLAC, they're lossless you won't lose anything.
3. If they're not FLAC then it depends if they're lossy or lossless, lossy, rerip, lossless then just encode to FLAC.
But first (as I already suggested in post #6) check the configuration of K3B or better, of both ripping software you're using.
If 1) and 2) of the aboves are true, you're sending the FLAC executables different parameters, if 3) you're using K3B definitely the wrong way and just re-ripping will do you more harm than good!
... I live by long distance.
