Topic: Need Help with FLAC tags (Read 3388 times) previous topic - next topic
First time messing with FLAC at all.  Was going to start Archiving my CD collection and wanted to save space on HDD and still have lossless audio so I decided to give FLAC a try.  I was looking on the official FLAC website and it suggested using MP3tag to edit FLAC tags, which is great because I already had that excellent program.  I used MP3tag to edit the FLAC tags and in WMP12 the only tag that shows up is the album art.  In Windows Explorer, none of the tags (including album art) show up.  Just wondering what I'm doing wrong?
Here's the .FLAC and .MP3 in MP3tag as you can see all tags are identical.  You can't see it, but I also clicked on extended tags and added the album art for both.
Here's the original .WAV, .FLAC, & .MP3 in Windows Explorer.  You can't see it, but in the lower left hand corner only the .MP3 shows the image art
Here's the .WAV (top) and .MP3 (bottom) in WMP12.  As you can see, the .WAV has some tags and some are incorrect while the .MP3 has all tags and are correct.
Here's the .FLAC in WMP12.  As you can see, other than the album art, there are NO tags.  Note: the title is not from a "title tag" its just from the filename.
Windows apps don't natively support FLAC. There's software out there that will make it work, though.
For instance (i haven't personally tested this one).
I've had limited success trying this in the past. Now i just sort my collection into 'artist' and 'album' folders, and use a media player that does support FLAC natively.
