Topic: ESplaylist album art search patterns (Read 2452 times) previous topic - next topic
Ok I recently joined club SSD and i lost/forgot most of my search patterns basically i need to look for any album art with the word front in it even if it's in ( ) or [ ]
thanks!
file>preferences>display>album art
*front*.*
I've got that one but it doesn't seem to work even when the file name has "front" in it.
it works for me.
you can check:
-that you definitely added it to the front section in the artwork preferences and that EsPlaylist is also configured to show the front. that can be changed somewhere in the advanced grouping settings.
-no other image files are taking precedent by being first. entries are processed in order from top to bottom and it stops whenever a pattern that matches is encountered.
-that the images live in the same folder as the actual audio files.
This is what i have set up
anything wrong?
go back to my first post.
these are the global settings for all of foobar. you've been using the columns UI settings.
ah thanks!
