Topic: CD Accurately Ripped in foobar, but not in CUETools? (Read 4799 times) previous topic - next topic
I have a CD as flac files. If i proof them in foobar2000 i became:
AccurateRip verification results:
Track  Status
01    Accurately ripped, confidence: 17.
02    Accurately ripped, confidence: 18.
03    Accurately ripped, confidence: 18.
04    Accurately ripped, confidence: 17.
05    Accurately ripped, confidence: 17.
06    Accurately ripped, confidence: 17.
07    Accurately ripped, confidence: 17.
But if i proof them in CUETools, i became "AccurateRip ID: ... disk not present in database":
[CUETools log; Date: 08.08.2013 15:26:24; Version: 2.1.4]
Using preserved id, actual id is 0013e849-00765a20-5c105707.
[CTDB TOCID: 3QViT9xPnVh8LyP9TWXCSzH.DEw-] found.
Track | CTDB Status
  1  | (5/5) Accurately ripped
  2  | (5/5) Accurately ripped
  3  | (5/5) Accurately ripped
  4  | (5/5) Accurately ripped
  5  | (5/5) Accurately ripped
  6  | (5/5) Accurately ripped
  7  | (5/5) Accurately ripped
[AccurateRip ID: 001aff0d-00c1a16d-72107d09] disk not present in database.
Track Peak [ CRC32  ] [W/O NULL]
--  100,0 [4A791D9E] [8BBE3968]
01  98,1 [BD1F97E7] [81D64F01]
02  96,1 [AB72CEB2] [1213751D]
03  100,0 [350EC380] [57E4B29A]
04  97,2 [33CA6B49] [6F92DAF5]
05  84,1 [259A4C13] [6731BC31]
06  55,7 [3FC7BB4F] [F7C690DF]
07  87,8 [6EC5F42D] [7E56F4E5]
Has anyone an idea, how i can proof the cd fils with CUETools as accurately ripped?
The cue sheet shows as DISCID: 5C105707.
CUETools is using the preserved AccurateRip ID from the tags instead of the one generated from the files [link]. Delete the AccurateRip tags from the CUE and the file tags (if exist).
Strange that the preserved id is for 9 tracks.
korth
I have deleted the DISCID from cue sheet AND from all tracks (there has been it as meta tag). But the result is equal, no difference.
Is there any other place, where CUETools stores local data?
I think the "09" is only hexadecimal data ("001aff0d-00c1a16d-72107d09" consists of 3 groups a 8 hexa digits. The same for "0013e849-00765a20-5c105707")
The DISCID was correct and didn't need to be deleted. I meant REM ACCURATERIPID from the CUE and ACCURATERIPID from the audio file tags (if exist). Or any tag that contains "001aff0d-00c1a16d-72107d09".
09 in HEX is 09 (with padding) and the last two digits in that group are HEX for the number of tracks. [link] [[a href='index.php?showtopic=79082']link[/a]]
Edit:
Yes, the local database (Local DB). You'll find the entries at the bottom of the Input: Folder Browser window. Right click on entries to edit or delete.
korth
delete ... ACCURATERIPID from the audio file tags (if exist).
Thank you, that was the reason  and Thank you for:
... i have learned a bit about ACCURATERIPID. (Anf thanks for the infos to "Local DB"  )
(The 09 tracks, come from 2 additioal little pause tracks (with 15 seconds of silence), which i use, because i like to have a pause between classical pieces. (and which i forgot to delete from my *.m3u-playlist, before i run CUETools-verify)
I will ask for a new feature in fb2k or a plugin, to play additional pause at the end of a track, which length is in a file tag "add-pause".
Do you know, which forum is appropriate for such request?)
Well, of course one of the subfora for fb2k, and reading their descriptions would make the answer clear: not Support because that is for problems, not 3rd Party Plugins because you seemingly want to ask the first-party developers, not Development because it is not related to your own programming, and therefore the last remaining option, which is General.
Thanks, for answering rapid and qualified
