Topic: Unexpected behavior in FhG AAC encoder (Read 26519 times) previous topic - next topic
Used:
- Foobar 2000 1.1.7
- enc_fhgaac.dll from Winamp 5.63 (tested settings VBR 3 / VBR 4)
- fhgaacenc.exe (20120624)
When converting a 32-bit float WAV file, if one channel becomes too quiet the resulting encode sounds like it's damaged. In my situation the problem occurs when left channel volume is between -18 to -19 dB while the right channel volume is between -125 to -130 dB. Obviously converting the WAV to 16-bit beforehand solves the problem, but that is a step I had not needed previously.
At first Winamp 5.63 'Format Converter' had the same garbled output but when I changed VBR settings the issue inexplicably ceased even after setting back to VBR 3  which I find even stranger.
If I had to guess, it appears the encoder is trying to juggle mid-side encoding and 'silence-encoding' (when it drops below 4kbps) :shrug:, something very unlikely to occur on CD material.
To simplify things for me, could you upload the original 32-bit WAV and the "buggy" MP4/M4A file please?
So does the louder channel also sound damaged, or only the quieter?
Chris
It just sounds like the file sustained damage. Depending on the decoder it either squelches and/or skips the affected area, or, stutters a little and continues play the rest of the file one octave lower.
Where shall I upload my audio clips?
edit: I am going to open a topic in "Uploads" section. Also, I should have said, "...continues to play the rest of the file one octave slower."
Didn't test yet but why don't you try again with the latest FhG's DLLs and the latest foobar2000 (don't think this will change anything).
No need to, I could already reproduce it. The encoder runs through, but the produced bitstream has some invalid frames starting at 6.5s.
Thanks for the report, Destroid, I'll take a look at this at work.
Chris
Ah, that was fast. Anyway, I was almost sure updated software would not help,but I just retested with FB2K 1.2.8 and enc_fhgaac.dll from Winamp 5.70b3417. Same result.
I also noticed 'Highest BPS mode supported' was set to 24-bits. I changed to 16-bits it seemed to remove the worst of the side-effect. I wonder if Winamp's 'Format Convert' did a bitrate conversion in the background when I changed settings but I could not replicate.
Glad to participate, HA ppl
New Winamp 5.7 Beta, build 3435 (with Winamp Cloud Beta)
Updated: [enc_fhgaac] Fraunhofer AAC Encoder v3.02.15
Maybe this fixes the problem?
Not yet, issue still exists. TBH I hadn't expected a quick fix anyway.
Shortly after I started this thread I tested several different other AAC, MP3 and lossy encoders, yet none of them exhibited the issue. My discovery of this bug with enc_fhgaac was blind luck since most users are unlikely to be working with resolutions above 16 bits where large differences in amplitude occur between channels (specifically when only one channel's signal is less than -112dB or whatever value of the threshold that is tripping up enc_fhgaac).
Indeed, we just finished a 03.02.16 release which fixes this issue, but of course this hasn't made it into Winamp yet.
Anyway fyi, even with 03.02.15 and earlier, VBR modes 1 and 6 (and the bit-rate-requivalent CBR modes) are not affected by the bug.
By the way, 03.02.15 includes some speed optimizations, so I'd be curious how much speed improvement you get for the VBR modes with the latest Winamp 5.65 over 5.63. On my old dual-core Athlon X2 it was between 10 and 20%.
Chris
Chris,
Do You tune quality of  your encoder or it's a bug fixes?
Thank You.
I had not thought of trying CBR. Although it is not much of an excuse, my portable player does not mind VBR AAC in contrast to its inability to correctly handle VBR MP3.
I ran a quick test on one CD album using --vbr 3 and the results are notable (Athlon64 3000+):
v5.63 = 28.04x, ave 116kbps
v5.65 = 34.50x, ave 114kbps
Nice!
23%, nice indeed. Thanks for testing.
Igor, during the last year, only bugfixes and speed-ups, and slight reduction in bit-stream size sometimes, esp. for loud music (see Destroid's last post, must be rock music?). Quality is probably the same.
Chris
Indeed, you have correctly guessed the genre. That particular album was somewhat dynamically compressed although not as horribly as other albums with RG -10dB or more. (Or is it less when its even louder?  )
I also want to apologize for misreading your post about VBR modes 1 & 6 not having the bug. I also did not test those settings either for the same reason that I was putting music on a portable but needed neither ultra-quality nor low-bitrate since most of the tracks I listen to are work-in-progress of home studio projects. (Imagine my shock when I heard that glitch in the encode and feared some part of my DAW was damaged  so I was glad it was a bug since software is more economically fix-able.  )
FhG tends to increase bitrate on rock music ... like Nero
Chris
Chris, thanks for the fix. I don't even know if I should ask this but, could you upload the DLLs (enc_fhgaac.dll, libmp4v2.dll, nsutil.dll) so we can test before the new Winamp?
will try to get the next beta build (though might be the one after that) to include the updated version of the FHG library. as it seems it wouldn't have been viable to include anyway at the time of v5.65 needing to be released.
The current, latest beta (5.7 Beta 12, build 3437) doesn't have .16.
Great, thanks. Yes, judging from the date the Winamp 5.65 installer mentions (July 23), it was impossible for us to finish our bugfix in time for that release. Is Winamp 5.7 the next release?
Sorry, eahm, no, those files are provided by the Winamp team, not us. Plus, to avoid having potentially buggy beta builds leaking around here, I'd prefer waiting for official Winamp builds.
Chris
If I may...
I don't think the bug I reported really affects most conversion usage. It was my own dumb agenda to directly convert 32-bit float WAV/PCM to AAC (along with other rare circumstances) that tripped this error.
I think Winamp's Fhg encoder is very, very good and users should enjoy the great quality and the optimizations of version 03.02.15 (and please bring some more speed comparisons on more systems  ). Also, I do not have any 24/96 DVD-A material to test. I can say downsampling to 16-bits is a viable workaround for the time, and also  that I have not reproduced this except on this 1 track. (My main interest: "Why? Can I identify why?)
I appreciate the communication of the Winamp team and the HA users, even if my reported situation is more the exception than the rule.
Been a long time Nero AAC user, then switched to QAAC (for true VBR mainly, though I can't say with certainty if quality is better, both are very good), so should I give this one a try? Sorry if I'm going a bit off-topic here...
Me too, that's one of the great things about HA: the fluent communication between developers and users.
Pardon the delay in responding. I would like to reference this 96 kbps AAC listening test.
I have always been impressed with HA's public listening tests and find them very credible due to the methodology being scientific rather than "warm fuzzy" feel-good. Anyway, the Fhg encoder from Winamp scores well in that test, as does QAAC, so when I got into portable players last year I went with the speedier encoder that delivered excellent results.
Why I was late getting into portable players? Let's just say I chose a non-violent alternative concerning an individual* at a public place of convening that had an internet jukebox, of which that individual escalated from annoying to belligerence.
* Internet jukebox fascist: one who monopolizes the machine with $10-$20 worth of selections and also kisses-up to the management to have others' selections skipped.
No apologies needed.
Thanks for that link. I believe I had rushed through those results some time ago, looking at them in more detail I see I have nothing to worry about (not that I had worries anyway, but still it's nice to see it). I'll surely go on with QAAC, though if I feel adventurous i'll transcode some lossless files to Fhg and give it a try. That said, I'm really confident in my inability to discern such tied performances.
Indeed. I have always been impressed with the whole methodology here, as well as with the knowledge and willingness to help of most members.
You mean speedier to encode into or speedier to decode from? The first is not really an issue for me (I'm young and can wait) but the second could matter more in the field of portable players.
Thank you very much, Destroid.
that's because no one on our side knew about it like Chris mentions in his following response. plus i said we'd try to get it into the next beta build which i naively assumed would be understood that it's not present in any of the current builds available.
v5.7 is currently on a rolling beta release plan with 'full' versions being provided in the interim if there's enough to warrant a build (e.g. v5.64) or if there's enough of a critical issue and appropriate fixes (e.g v5.65).
there'd just be buggy Winamp beta builds instead floating around
Beta 13 still doesn't have .16.
