Topic: Lyrics tab on fooplacebo (Read 2705 times) previous topic - next topic
Hello,
I've been using the fooplacebo skin (you can check it here) and it's simply amazing, but it do not comes with support to lyrics panel 3, as you can see in this print .
I've been trying to change it to lyrics panel 3 using the layout menu, or the splitter settings menu, but I always end up messing up the whole thing. Could anyone please give more detailed instructions of how to change it, if it is possible? I'm using foobar version 1.2.8.
Moved to "3rd Party Plugins" forum since this skin is based on Columns UI.
This should be fairly straightforward since it looks like there is already a lyrics panel present, presumably lyrics2. Locate this lyric panel in the layout and add lyrics3 in the same parent panel stack splitter (I assume this is being used). Select the parent panel stack splitter and choose configure. Ensure all panel settings on the panellist tab for the original lyrics panel and lyrics3 are the same. In particular, ensure use of forced layout is the same and rename foo_ui_lyrics3 caption so that it has the same name as the original lyrics panel (alternatively you can change all instances of the lyric panel name in the script so the name matches that used for lyrics3). Remove the original lyrics panel from the layout.
Well, it worked fine here, thank you very much for the guidance.
