Topic: Some confusion about size of header-sideinfo mp3 (Read 4272 times) previous topic - next topic
Counting the number of bits used by the sideinfo, I get 18.8 bytes.
Note that the side info is defined to contain the following parts:
  • main_data_begin (9bits)
  • private_bits (5bits)
  • scalefactor_selection_info (4bits)
  • side_info_granule0(66bits)
  • side_info_granule1(66bits)
I hereby used the option for single channel and the window_switching_flag set --- so region2 is empty and only two regions are coded.
So my question is: why doesn't it add up to 136 bits (17 bytes), as the standard specifies it to be?
[Resolved] The size of the side_info_granule I calculated was incorrect. To rephrase, the information contained in the side_info_granule_(0 or 1)-field:
  • block_type(2bits,4bits)
  • mixed_block_flag(1bit,2bits)
  • table_select (10bits,20bits), or when window_select_flag = 0, (15bits,30bits)
  • subblock_gain (9bits,18bits)
  • region0_count (4bits,8bits)
  • region1_count (3bits,6bits)
Where the first amount of bits between parantheses is for mono- and the second for others modes.
In the case that the window_select_flag = 1,  region2 is empty so only two regions are coded. Hence, in mono mode we have 5*2*1 = 10. 5 bits are needed to specify the specific Huffman table; 2 regions to be coded; 1 channel (mono mode). A similar argument goes for the dual channel case, and with the window_select_flag = 1 --- and hence all three regions are coded.
Secondly, when window_select_flag =  0 the fields block_type, mixed_blockflag and subblock_gain are not used.
When considering these issues, the number of bits add up to 136 (mono) or 256 (dual channel). Namely, for mono mode and window_select_flag = 0 we have for the window_select_flag-dependent fields:
  • table_select (3 * 5 bits), namely 5 bits are needed to specify the Huffman tables and 3 regions are coded. (3 regions are coded because window_select_flag = 0)
  • block_type (2bits), not used because window_select_flag = 0
  • mixed_block_flag (1bit), not used, (")
  • subblock_gain (9bits), not used (")
  • total = 15 bits;
for the rest of the side_info_granule fields:
  • part2_3_length (12bits)
  • big_values (9bits)
  • global_gain (8bits)
  • scalefac_compress (4bits)
  • preflag (1bit)
  • scalefac_scale (1bit)
  • count1table_select (1bit)
  • window_switching_flag (1bit)
  • region0_count(4bits)
  • region1_count (3bits)
  • total = 44  bits;
for the general field that isn't part of the side_info_granule-field:
  • total = 18 bits
So total bits per granule: 15 + 44 = 59 bits. There are two granules per mp3 frame so we have for the total size of the sideinfo: 2 * 59 + 18 = 136 bits = 17 bytes.
Indeed, this is consistent with the standard. A similar argument goes for the case of other modes and with the window_switching_flag = 1.
Sources:
  • D. Salomon, Data Compression: The Complete Reference, text book, p.818-819
  • P. Sripada, MP3 DECODER in Theory and Practice, master thesis, p.24-25
  • R. Raissi, The Theory Behind Mp3, paper, p.13-17
