Topic: Streaming issue (Read 1581 times) previous topic - next topic
Streaming issue
Hi Guys,
foobar2000 is having problems streaming from http://www.dnalounge.com. These are the URL's I am trying to use...
http://cerebrum.dnalounge.com:8001/audio/2...05-22-15958.mp3
http://cerebrum.dnalounge.com:8001/audio/2...05-24-00000.mp3
I've upgraded to the latest version and the streaming problem still exists as described below...
The problem...
When I have my transparent proxy disabled or enabled without specifying a proxy in IE the stream will only play for 1 second.
Here is a description of what I have tried with the outcomes...
Note: I have a transparent proxy running on my network that redirects all traffic on port 80 to 8000 through the gateway box.
I set IE to run through my ISP's proxy server proxy.netspace.net.au:8080. Restarted foobar2000 and the stream worked fine. Transparent proxy still enabled.
So then I set IE to use the local proxy server which is 192.168.3.1:8000. Again All works fine. Transparent proxy still enabled.
I then disabled the transparent proxy completely, removed IE proxy settings and restarted foobar2000 the stream only plays 1 second then stops.
I then enabled the transparent proxy with no IE proxy settings and restart foobar2000 - the stream only plays 1 second then stops.
I directly connect my Windows box to the Internet with no firewall - again the stream only plays for 1 second then stops!
Winamp seems to work fine in all the above configurations. I don't know if this is a foobar issue but why is it working through the proxy ok?
Any suggestions??
Kind Regards,
zoltak
