Topic: Adjust volume while decoding to wav (Read 5200 times) previous topic - next topic
Hi
I use the solution from subsonic.org to stream my music to my smartphone and tablet. It's really a great tool, as ypu can decide how your source files should be recoded. I recode my 256 Kbit/s AAC to 112 KBit/s AAC by using qaac with following two steps:
I use this transcoding command:
Step 1: ffmpeg -i %s -f wav -
Step 2: qaac -a %bk --adts - -o -
This works great but replaygain get's lost. Now I'm looking for a solution to change the volume when decoding the files in step 1. FLAC has this feature called "--apply-replaygain-which-is-not-lossless" which is exactly what I want (remember, it's only for streaming!). Does someone know a decoder which supports that too but for decoding aac (and possibly mp3)?
Thanks in advance!
There's the tool xrecode, that allows a direct conversion to aac or mp3, and adjust the volume on the fly too (in a lossy way, if you wish).
AFAIK OP wants streaming, not converting to a file.
neroaactag can read and print m4a tags, but you need to use awk or something to extract the gain value for later application.
As for gain application, you can also pipe ffmpeg output to sox and use vol effect of sox. Since sox accepts dB form, you can omit dB->amplitude calculation.
Thanks for your help!
@exxtrabigmehdi: I need a codec/tool which supports stdout (as lvqcl mentioned) and I don't know if xrecode supports that. But I contacted the developer.
@lvqcl: Correct, thanks for pointing that out! Since xrecode can be run by commandline it's maybe possible that it supports stdout? As I said I asked the developer.
@phofman: Thanks for the link. This might be a solution. I'll try to script something as soon as I find some time.
@nu774: Thanks for that. This might be a solution too.
Big_Berny, what OS do you use? I assume windows due to qaac and xrecode...
Yes, I use windows.
I thought it would be simple - just making a named pipe in place of the file and reading the pipe to stdout of the script. Oops, no named pipes of that type in your OS
Depending how much time and effort you want to put into solution, you might want to play with tail -f of http://sourceforge.net/projects/unxutils/ and background processes in cmd scripts http://stackoverflow.com/questions/1449188...-asynchronously .
Uff... Looks more complicated as I expected. So there is no easy way to script in windowS?
I've just noticed that xrecode now support stdout according to the changelog (well,  this feature was added a month ago) . If you have other feature request, don't hesitate to contact the developper again, they are often considered.
